Rear Leaf Spring (Spring Rate)
Old Jul 3, 2019 | 09:53 AM
'18_F250_4x4's Avatar
'18_F250_4x4
Generally stated:
Spring rate is the amount of force that is required to move a spring and is measured in pound-force per inch (lb-in)
Ok so I know there are several different STOCK rear spring configurations so a general question is a waste of time and will get responses referring to the many different springs installed on these trucks SO:
With the truck sitting static is there any data on the actual weight (tongue, pin or passengers/cargo box weight) required for each stock rear spring to start compressing?
I would think there is some information other than just the MAX load rating and I would guess the springs can handle a certain amount of weight before deflection (compression) begins.
Any ideas?
Old Jul 3, 2019 | 12:12 PM
crewzer's Avatar
crewzer
The springs are already compressed when the truck is not loaded due to the sprung weight at the back of the truck. The empty bed weighs ~400 lbs. The springs will deflect further when the bed is loaded.
HTH,
Jim / crewzer
Old Jul 6, 2019 | 09:25 PM
'18_F250_4x4
Found this "Chart" in a different post about rear springs and while not familiar with the way the springs are rated or classified I would take the 7th column as the different weights at which the springs are engaged and start to deflect which kinda answers my original question.
Any weight I understand should cause a deflection but does this chart state that first number LBS fully engages (deflects) the first stage, the second and third as well?
Old Jul 6, 2019 | 10:20 PM
Sport45's Avatar
Sport45
The chart tells part of the story. You can tell how much weight it takes for the first inch of deflection. You don’t know how many inches of deflection you get at each spring rate.
Old Feb 21, 2020 | 01:50 PM
powerscol's Avatar
powerscol
Is this information available for the 2020F350 MAX GVW 11400lbs
Old Feb 21, 2020 | 03:03 PM
crewzer's Avatar
crewzer
See page 60:
https://madocumentupload.marketingas...fb6b7&v5=False
HTH,
Jim / crewzer
Old Feb 21, 2020 | 04:05 PM
powerscol's Avatar
powerscol
Originally Posted by SDcrewzer
Thanks so much
Old Feb 22, 2020 | 10:35 AM
powerscol's Avatar
powerscol
It appears from page 60 I will see just over 2" of drop at 1500 lbs. However what is not clear is should I include the bed weight. Cart does not say if pr loaded with bed. In other words compression is based sole on cargo weight. If I add the bed weight I might see 3.5". Thoughts?
Old Feb 22, 2020 | 11:37 AM
crewzer's Avatar
crewzer
My recollection is that spring rates are based on resting (unloaded) states. Accordingly, deflection calculations should be based on total applied force.
However, as aptly pointed out above, we don’t know where the rate-change displacement measurements are.
HTH,
Jim / crewzer
Old Feb 22, 2020 | 12:08 PM
powerscol's Avatar
powerscol
I would guess the change is at each weight point
First 350 lbs nets 1" I assume at this point the second stage starts
Next 700 lbs is another inch or we should see 2nd inch overall. Then the third stage kicks in
Then for every 1400lbs after that is an inch.
Whats not know is the deflection linear with the increased weight, especially the 3rd stage
In another thread I have ask folks to post the deflection they are getting with what loading. No responses yet.
Thanks for the help on this
Keith
Old Oct 19, 2022 | 06:40 PM
Back2Gas?'s Avatar
Back2Gas?
Keith
Did this ever get resolved? I'm looking to estimate how much my new F350 will squat when I hook it up to my relatively light 5th wheel. I don't have bedlining or a hitch yet and am concerned about how tall it is compared to my old F250...
Old Oct 19, 2022 | 08:19 PM
chadstickpoindexter's Avatar
chadstickpoindexter
FWIW, here’s the same chart as posted above, but for the 2022 MY.
Old Oct 20, 2022 | 09:18 AM
Back2Gas?'s Avatar
Back2Gas?
Thanks!!!!
Holehawgg
Apr 8, 2012 04:58 PM
jerseyphil
Aug 11, 2010 04:48 PM
SmokeWagon
Feb 28, 2006 06:14 AM
RawPower
Jun 16, 2005 02:58 PM
jor1369
Apr 8, 2005 10:32 PM
