Disable auto start stop
Old Jul 2, 2019 | 07:54 PM
gump2388's Avatar
gump2388
I have a 2019 f150 with the A.S.S. Id like to disable it thru forscan but dont want to lose the bms.
is there another way to do it? I have hptuners and can remove it there but i dont know if the bms goes away there too.
Old Jul 2, 2019 | 08:15 PM
Robbgt's Avatar
Robbgt
I ran into the same dilemma - didn't want to disable the BMS. Had toyed with unplugging the last connection near trailer brake module but didn't like this would disable trailer lights. I don't tow often and would forget it was unplugged.
Ended up picking up auto stop eliminator. Took 5 min to install and completely reversible.
$10 off with discount code "autovlog"
https://www.autostopeliminator.com/
Old Jul 2, 2019 | 08:22 PM
gump2388's Avatar
gump2388
Do you know if it does infact not disable the bms? Im wondering if the system is tied together.
Old Jul 2, 2019 | 09:55 PM
ford390gashog's Avatar
ford390gashog
BMS has to be disabled separately. I have both disabled.
Old Jul 3, 2019 | 04:25 AM
gump2388's Avatar
gump2388
Using forscan or with the device linked above?
Old Jul 3, 2019 | 06:26 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
The device only disables the A.S.S., it interrupts the switch to turn it off.
hillcountryflt
2015 - 2020 F150
Oct 8, 2025 06:10 PM
hillcountryflt
2015 - 2020 F150
Mar 25, 2019 02:31 PM
ETKMS
6.4L Power Stroke Diesel
May 2, 2012 09:53 AM
Ford Fx4
2009 - 2014 F150
39
Mar 28, 2012 09:15 PM
76cruiser
Electrical Systems/Wiring
Dec 23, 2010 02:32 PM
