Brake controller issues
Old Jul 2, 2019 | 03:05 PM
Steve Snyder's Avatar
Steve Snyder
4wd High
I posted this in the towing section but thought maybe someone here could help me. Thanks in advance
@Steve Snyder , Today 08:03 PM
I have a 2017 f250 diesel crew with intigrated brake controller. I have towed 2 new trailers with it. Both times even with the gain set all the way up and the surge setting set To high the brakes are only slightly apply when sliding the actuator lever fully over during a brake check. In fact it seems like no matter what the gain is set on the brakes engage the same and that is barely. I should be able to get a new trailer to lock up I would hope. One trailer was 8000 one was 9500. I read somewheee it may need to be reprogrammed or flashed at the dealer. Any help? Thanks so much!’
Edit
Old Jul 2, 2019 | 03:20 PM
mhoefer's Avatar
mhoefer
You have it set to all the correct settings, like conventional trailer, electric or elect over hydrolic, there is a low medium high setting for brake strength AND the brake setting goes up to 9.9. First one in the dash settings on the trailer set up, second one +/- buttons right beside the controller slide handle.Its also unlikely but possible both trailers had their brake pads set to far away, not adjusted, you would have to rule that out with another truck on same trailer, or another trailer that works on your truck. I have not heard of the re flash thing but indefinably get the dealer to test it and look into. Did you set up each trailer in your dash settings ie Bob's Tandem, Joe's Gooseneck, personal Travel Trailer, and then review all settings and compare to rule out your issues would be where I started. I have pulled several trailers with mine and have not had an issue as yet with any. Works really good. Also, to doa brake tug test, some have to use the slider at over 5 mph for it to actuate.
Old Jul 2, 2019 | 06:29 PM
senix's Avatar
senix
I would start with pulling the brakes on the trailers and looking at them. Confim that each is getting power and at what amerage.
Be advised you are not going to get the tires to lock up.
Old Jul 3, 2019 | 01:44 PM
minke's Avatar
minke
Edit
When I search the '17 Owner's Manual the only 3 hits searching for surge were for surge brakes which the TBC can't control.
Old Jul 4, 2019 | 04:38 PM
RumpityRump's Avatar
RumpityRump
WOW!!!!!!! Ford still did not fix this issue! I have a 2015 with the same problem. Many people have talked about it. No fix as of yet. This Sucks!
Old Jul 4, 2019 | 04:48 PM
mhoefer's Avatar
mhoefer
Rumpity, its not verified issue until the OP reports to us actual results. But it does still seem some have issues.
CrossCut
2009 - 2014 F150
Nov 20, 2019 07:14 AM
Top_Speed1
Aug 29, 2017 08:27 PM
hikeril
6.7L Power Stroke Diesel
Jun 22, 2015 05:46 PM
Great Danes
78
Nov 14, 2013 09:25 PM
Bronsonh
Apr 27, 2009 10:55 PM
