How do I clean the MAF?
Old Oct 5, 2003 | 04:06 PM
TxColt's Avatar
TxColt
Question How do I clean the MAF?
I have the pinging problem that has been addressed several times in the forum. My 99 Ranger 4x4 3.0 automatic w/81k pings under load, but the ping diminishes at higher rpm's. I've replaced the air filter and spark plugs (autolite douple-p....I know, some don't care for these), and have even used higher octane fuel. the pinging will subside for a tank or so, then return. I had similar ping in an '87 f-150 I-6 4 speed I used to have. I just learned to deal with it.
My question is how do I clean the MAF, the IAC and similar shade-tree jobs that I can do. I've given myself a migrane attempting to find all this on my own. I'm on a limited budget, just as many of you guys are. I would appreciate any and all help. Thanks!
PS. I only use my Ranger for running my rural mail route of 100 miles/day (60-70 % dirt roads...if you wanna call it dirt) and bouncing around the pasture. All B.S. aside, I have had the very best experience with fords(on my 4th). Had a goat...too much body noise and fed it too much gas - rolling it on the interstate was the best thing that happened to me in 2001. After that, shelled out the cash and bought, at that time, my dream truck! A brand new shiney red Z-71 ext. cab with all the bells and whistles. For such a "tough" truck, I had to do a crap-load of maint.!!!! traded it for a 2002 S-duty......been exstatic ever since! (thank you superchips) BTW...wifey drives the s-duty
Old Oct 5, 2003 | 05:07 PM
Rockledge's Avatar
Rockledge
Try this:
Cleaning Your MAF Sensor
Old Oct 5, 2003 | 06:04 PM
TxColt's Avatar
TxColt
Thanks!!!! wonder why that didn't come up on my search?? Anyway, you saved me a lot of time. As my dad always says, "Thanks 'till you're better paid"!!
Old Oct 5, 2003 | 07:15 PM
Rockledge's Avatar
Rockledge
You're welcome. Let us know if it helps the pinging.
Old Oct 5, 2003 | 07:33 PM
Mike W's Avatar
Mike W
Rolling on the interstate doesn't sound like fun. I hope you didn't get hurt.
Old Oct 6, 2003 | 12:58 AM
TxColt's Avatar
TxColt
Only very slight pinging at low rpm's under load such as a good hill. Now if I could find some decent gas around here....thanks guys!!
My left shoulder warns of impending weather now, but it's cool. I got lucky. Passenger side....fubared. Driver side...not a scratch. I'll try to post pics. thanks for the concern!
Old Oct 7, 2003 | 06:30 PM
wolfen's Avatar
wolfen
Ay! TxColt;
Now that I'm experienced in this area, I can pass this info along you're question:
These 3 items are what I've done so far: On my 90 Ranger 2.3L, there may be some differances than w/ your 3.0: I Simply removed the 4 screws holding on my Throttle Body. Both the IAC + TPS were connected to it. The IAC is a long valve w/ a 3 wire connect coming from it + 2 screws hold it in place onto the body. The TPS has a 4 wire connect also w/ 2 screws holding it in place. The MAF; located on the filter housing, has a 4 wire connect + 4 screws holding it in place. Go to Sticky: Tech Info for more.
Bubba Jones
1978 - 1996 Big Bronco
Jan 23, 2014 04:05 PM
pidaster
Aug 30, 2011 06:43 PM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
turkee56
3.0L V6
Jun 11, 2006 03:32 PM
speedracer29
Feb 10, 2003 01:11 PM
