94 IDI injection pump timing?
Old Jun 30, 2019 | 12:49 PM
msta999's Avatar
msta999
Hi, I replaced the injection pump on my 7.3 IDI, but didn't have the tool to set the timing. It runs good, but my mpg is only 15.5, it was 19 and 20 before and I notice some soot in the tail pipe, which was not there with the old injection pump. I want to turn the pump a little to see if my mpg will come back up, but don't know which way to go. Any recommendations? should I turn it towards the passenger side or the drivers side? Oh, and I replaced the injection pump over a year ago.
Old Jun 30, 2019 | 04:42 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
toward the passenger side to Advance
you really need a timing meter... but whatever
Old Jun 30, 2019 | 09:56 PM
hairyboxnoogle's Avatar
hairyboxnoogle
more soot sounds like its too advanced, i would rotate it to drivers side about 1/16" and see if it improves or gets worse.
Old Jun 30, 2019 | 10:33 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yeah probably, from my experience advancing can give better fuel mileage and produce more pollutants .... retarding can cause lag and run a bit cleaner.. fine line there LOL
but I was just pointing what direction to move the pump for advancing ... the advise was use a timing meter it sure just takes the guess work out of it for me
Old Jul 1, 2019 | 12:47 AM
msta999's Avatar
msta999
I try'd finding some place that had one, but no one around here (Wasilla, AK) has one, everyone says they just mark the injection pump to the housing, but the new pump didn't have a mark on it.
Old Jul 1, 2019 | 09:55 AM
Olds64's Avatar
Olds64
Does your truck have a pyrometer? If you just replaced the IP you could turn down the fuel screw a flat or two.
Old Jul 1, 2019 | 10:20 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
BTW I think 2 degrees of timing movement is about 0.030 movement of the pump. ... I generally set mine between 4 and 5 degrees.
it is strange to not see a timing mark on the Pump, all replacement pumps I have messed with Had a mark, but it's been probably 20 years since I have changed one so I have no Idea if new ones are still marked today, I would assume all rebuilt pumps would have a mark.
Old Jul 1, 2019 | 11:41 AM
msta999's Avatar
msta999
I worked at a ford truck dealership in the 90’s and like you said, there was always a mark, but I used a timing light and trigger pickup ( or what ever it is called) to set the timing.
Ill advance it (tip it to the drivers sit) a little and the see what my mileage looked like
Old Jul 1, 2019 | 12:07 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yeah I use a Fox Valley 160 with an MT1480A Lumy/Mag ... I don't have the Snapon Lumy Probe but the FV160 works just great with it.
they make some vibration Timing adapters that you can connect around the fuel line too, but I have never used one.
I've seen a few folks make their own probe from a burned out Glow Plug and a Photo Transistor, it's really pretty simple, cost about 10 bux.
Old Jul 1, 2019 | 01:23 PM
msta999's Avatar
msta999
This doesn't ring any bells....don't know what your talking about.. Will it affect timing?
Old Jul 1, 2019 | 01:30 PM
Olds64's Avatar
Olds64
The screw on the side of the IP effects fuel delivery. People turn it up a few flats to "roll coal." This will cause your EGTs to go up too.
Where did you get your new IP? Do you know if it was set properly from the rebuilder?
Old Jul 1, 2019 | 01:36 PM
msta999's Avatar
msta999
Try'd looking up, making my own, but didn't come up with anything.
Old Jul 1, 2019 | 04:04 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the tricky thing is drilling out the old Glow Plug so you can install a Quartz Rod in it, and you need to put threads inside the top end of the GP so that you can screw in a Bushing to hold the Quartz Rod in place so it don't blow out and Poke an eye out. the electronics are pretty simple just a 4011 Quad Nand gate to be triggered by a Photo Diode/Transistor, and a 2N2222 NPN transistor to be driven by the NAND Gate thru a Wire Loop to trigger your Timing Light/Meter.
maybe I'll draw up a Schematic and post it Later.
Old Jul 1, 2019 | 04:18 PM
msta999's Avatar
msta999
That at would be nice, might help someone else too!
Old Jul 2, 2019 | 12:05 AM
DarkOverCast's Avatar
DarkOverCast
I'm assuming you use this diy probe with a regular "gasser" timing light? The one that flashes?
If so I'd definitely be interested in the diagram if you have time.
