Sponsored by: Real Truck
Window problem
Old Jun 27, 2019 | 08:07 PM
MTRoofer's Avatar
MTRoofer
Window problem
2015 f350, rear passenger window will not roll back up. Replaced the motor and regulator. Probe light shows power through both switches and into the plug for the motor. Will roll down but not up with both new and old motor. Any help would be greatly appreciated. Thank you
Old Jun 27, 2019 | 10:44 PM
MTRoofer's Avatar
MTRoofer
Anyone have any ideas?
Old Jun 27, 2019 | 10:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Does it make any effort to roll-up or does the motor just not engage?
If it tries and fails, check for physical blockages, then try this:
To override a bounce-back condition, within two seconds after the
window reaches the bounce-back position, pull and hold the switch up
and the window will travel up with no bounce-back or pinch
protection. If the switch is released before the window is fully closed,
the window will stop. For example, this can be used to overcome the
resistance of ice on the window or seals.
Old Jun 27, 2019 | 10:57 PM
MTRoofer's Avatar
MTRoofer
The motor doesn’t engage to go up. It will go down. There is power at the plug to the motor for up and down.
Old Jun 28, 2019 | 08:40 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Maybe it's the switch? Can you supply power directly to the motor and will it go up?
Old Jun 28, 2019 | 08:42 AM
MTRoofer's Avatar
MTRoofer
When I unplug the harness at the motor, I have power up and down when I activate the master switch on the front door and with the switch on the rear door. Seems as if I have power all the way to the motor.
Old Jun 29, 2019 | 08:03 AM
5851a's Avatar
5851a
You also need to check and make sure you have ground. Someone may have a diagram or a shop manual diagnostic procedure. Sorry I don't for anything past early 80's.
sealer700
May 1, 2016 05:08 PM
Anderson3476
Sep 19, 2013 10:20 PM
shotgun64
May 18, 2012 04:00 PM
shadetree mech.
Nov 22, 2005 03:17 PM
