Sponsored by: Real Truck
POWER WINDOW HELP!
Old May 13, 2012 | 04:34 PM
shotgun64's Avatar
shotgun64
POWER WINDOW HELP!
My power window will not go down all the way down on my F250 the motor is good I think the motor works when I have it out. If i push down on the window it works. Motor does get hot. Any ideas thank you.
Old May 18, 2012 | 01:46 PM
BigBlue99's Avatar
BigBlue99
Replace that motor hoss. Its probably worn out. I had a problem with my motor not working all the time but after replacing with aftermarket it started the same thing 8 months down the road. I replaced everything but that 8 month old motor (switches, relay, and all); now I have replaced the electric windows with manual and I will never deal with it again. whatever you do go and buy the ford motor. I bought aftermarket on other trucks and have regreted it. OEM parts are typically better, but are also typically more expensive.
Old May 18, 2012 | 04:00 PM
shotgun64's Avatar
shotgun64
I lubed the window tracks and they work great so far. If it does it again I will replace the motor. Thank you BigBlue99.
sealer700
May 1, 2016 05:08 PM
almonyspm1
Sep 14, 2011 09:00 PM
*2fords*
Jul 17, 2009 01:24 PM
shadetree mech.
Nov 22, 2005 03:17 PM
