Running Transmission lines
Old Jun 27, 2019 | 09:18 AM
56exp's Avatar
56exp
I have a C-6 and external cooler from the RV the motor came from and superior radiator. Does it matter which way the lines are run. I think front line on trans is out (pressure) and rear is return.(could be wrong) Was planning to go to right on radiator ,from left to out front to ex cooler, then back to trans from ex cooler. This is a 56 F100 8'. Someday l will figure out how (find the time to figure out) to get pictures from a camera to computer or pad. I read this forum all the time and really appreciate the info and time you all spend helping others and write up of projects. It has been said may times Best site ever! Thanks Dean
Old Jun 27, 2019 | 08:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The front port on the trans is the output. You are correct that this line goes to the radiator cooler. Then the other port from the radiator goes to the aux cooler, and the other one from the aux cooler to the rear of the trans.
Old Jun 27, 2019 | 10:03 PM
jniolon's Avatar
jniolon
old and in the way
this might help
j
https://www.fordtruckzone.com/thread...-f-100.664344/
Old Jun 30, 2019 | 12:52 PM
56exp's Avatar
56exp
Thanks that helped Dean. Both answers thank you
lud04X
Aug 15, 2016 09:21 AM
grec-o-face
Jul 14, 2012 01:42 PM
Drac
Nov 23, 2011 11:39 AM
parcours
Sep 6, 2005 08:29 AM
skywagon
Mar 23, 2004 11:34 AM
