C6 Trans cooler lines
Old Nov 14, 2010 | 08:11 PM
Drac's Avatar
Drac
Save the old ones
Of the 2 fittings on the side of the case where the oil cooling lines attach, which is the supply and return?
I am assuming the fitting in the front is the pressure as it is closer to the Pump.
The reason I ask is I want to run the trans fluid through the radiator first then through a Cooler.
Old Nov 15, 2010 | 02:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You are correct. The front fitting is pressure out. It goes to the radiator cooler. The rear is the return from the coolers.
Old Nov 16, 2010 | 12:09 AM
Drac's Avatar
Drac
Save the old ones
Thanks Mark.
Greatly appreciate it.
Old Nov 21, 2011 | 08:53 AM
bruno2's Avatar
bruno2
So I am assuming it goes in a loop through the radiator and then from the radiator through the cooler and back to the tranny?
Old Nov 21, 2011 | 04:40 PM
Mark Kovalsky
Yes, that's correct.
Old Nov 23, 2011 | 11:39 AM
Ken Blythen's Avatar
Ken Blythen
On my truck, the line from the auxiliary cooler back to the trans, has one short section of hose (original) joining two steel lines approx under the radiator.
But the line from the trans to the radiator (hot oil) is all steel.
4byford
Mar 14, 2017 08:01 AM
brennanforgeron
Feb 2, 2017 01:45 PM
Dflynn926
1978 - 1996 Big Bronco
Dec 6, 2016 12:43 PM
brennanforgeron
15
Nov 14, 2016 10:31 PM
lud04X
Aug 15, 2016 09:21 AM
