Temperature Gauge Doesn't Move
Old Oct 5, 2003 | 10:54 AM
knockturnalstorm's Avatar
knockturnalstorm
I have a 2000 Explorer Xlt 4x4 Now here's the problem I can drive this thing for hours and the temp gauge never moves past cold I doesn't overheat and it gets good heat so Im wondering if maybe it could be like a stuck thermostat or maybe a bad sending unit
any suggestions?
Old Oct 5, 2003 | 11:24 AM
84ford460's Avatar
84ford460
You don't have a stuck thermostat. Unless you live where it is always hot all the time. Start your rig when cold and take the radiator cap off. Watch the coolant. When the thermostat opens the coolant will start to flow. It will be fast enough that you will know that the thermostat opened. I would venture to say that the sending unit is bad on your rig. Could also be the gauge itself is BO.
I'd try the sending unit first. That's the easiest and cheapest to try.
Larry
1993 Explorer 4x4
Old Oct 7, 2003 | 06:38 PM
knockturnalstorm
so anyway today was the first day I've had off in like three weeks so I decide to decarb my engine today I had a real nasty carb build up I so any way I do this and I take it out to test it when I was done and the temp gauge starts working so I have no Idea what might have been wrong but the gauge is working fine
Old Oct 7, 2003 | 07:51 PM
84ford460's Avatar
84ford460
Sounds like you might have had a loose connection. Check the plugin on the sending unit for dirt/grime or a frayed wire.
Glad it started working!
bubbasz1
6.4L Power Stroke Diesel
15
Jul 20, 2017 01:14 PM
Jpilcher
New Member Introductions
Apr 15, 2017 01:37 PM
Truck Noob
Feb 21, 2016 09:45 PM
Johno.h
20
Jan 13, 2016 12:36 PM
Bowstring
Mar 27, 2008 08:50 AM
