1952 Upper Radiator Hoses:
Old Jun 26, 2019 | 12:53 PM
leonharu's Avatar
leonharu
Does anyone make molded upper radiator hoses for 1952 F-1 flathead engine.I know you can get a universal flex type.I don’t care to deal with the steel pipes and hoses!
Old Jun 26, 2019 | 07:01 PM
Mixer man's Avatar
Mixer man
I don't think so, but what I've found to work in similar circumstances is to find a pre-formed hose from a different application and cut the section I want out of it. This requires going behind the counter and sorting through the inventory, if they'll let you.
Also, if you don't care to deal with steel pipes, apparently there is a PVC alternative as witnessed in another thread.
Old Jun 26, 2019 | 07:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Some Ford cars had one-piece hoses, but they were a lot shorter.
Bob, where is this thread about PVC? It's only rated to 140 deg.F., I can't imagine that turning out well. Even CPVC is only good to 180.
Old Jun 26, 2019 | 07:38 PM
Mixer man's Avatar
Mixer man
It's that pole truck on Craigslist. Appears to have a 2-1/2" large sweep 90 degree conduit cut down. Some people instantly get in over their heads.
Old Jun 26, 2019 | 08:02 PM
leonharu's Avatar
leonharu
I wonder if these would work?I guess they are for just the car.
https://www.macsautoparts.com/store/...Product_Viewed
Old Jun 26, 2019 | 08:19 PM
52 Merc's Avatar
52 Merc
If they're long enough, they should work fine. You might try calling Mac's and see if you can get a measurement. Just out of curiosity, what's the aversion with the metal pipes?
Old Jun 26, 2019 | 08:44 PM
abe's Avatar
abe
Yeh, what's wrong with metal OEM Pipes?
Old Jun 26, 2019 | 08:52 PM
leonharu's Avatar
leonharu
Wayne,I guess there is nothing really wrong with using the metal pipes.I always thought there was to many clamps and to many hoses for more chance for leaks.I have the universal flex that have been on my truck for probably 25 years or more and figured it was time for a change.I never had much luck with those factory looking clamps they sell either.
Old Jun 26, 2019 | 09:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
p/n 1BA-8260, Dennis Carpenter has them for $5 less: https://www.dennis-carpenter.com/en/...radiator-hoses
I'd think you have a better chance asking DC to measure them than the goobers at MACS.
I think if they did fit, Ford would have used them ($$$ savings)
Old Jun 26, 2019 | 09:22 PM
leonharu's Avatar
leonharu
Thanks Ross I will call Carpenters and check just to see if they may work.
Old Jun 26, 2019 | 09:28 PM
Mixer man's Avatar
Mixer man
Of course you could check the part numbers against your parts book. A quick Google search turns up that 1BA-8260 part number is for cars only.
https://www.google.com/search?client...tus&q=1BA-8260
CharlieLed
18
Oct 14, 2015 01:12 AM
John - NNY
Jun 17, 2011 07:45 AM
Flathead 51
Jan 30, 2010 05:09 PM
going slow
Feb 25, 2008 12:38 PM
