Temp. guage not working
Old Oct 5, 2003 | 01:13 AM
dstarrington's Avatar
dstarrington
I just remembered another question for my 95 Explorer, the temp. guage dosen't move but 2 needle lengths at any time hot or cold. Any suggestions on fixing?
Old Oct 5, 2003 | 02:27 AM
c96drumm's Avatar
c96drumm
Might be the thermostat stuck open or a bad sender or a bad connection to the sender or instrument panel. Could be the gauge, but probably not. Someone correct me if I'm wrong, but I think that if you take the wire off the sender and ground it, the needle should go to full hot. If it does, it's a bad sender. If not, it's one of those other things.
Old Oct 5, 2003 | 03:32 AM
marragtop's Avatar
marragtop
I agree, grounding the sending unit wire should peg the gauge. If it does, then assume the gauge is OK. This doesn't necessarily prove if the sending unit is good or bad. If the gauge normally moves somewhat, your thermostat might stuck open and should be replaced. I'd start with replacing the thermostat since that is considered to be somewhat 'normal' maintenance.
Old Oct 5, 2003 | 09:05 AM
c96drumm's Avatar
c96drumm
You're right. Thermostat first.
Old Oct 5, 2003 | 11:24 AM
dstarrington
temp. guage
Thanks to everyone, I really appreciate the help. I will start with the thermostat and give you an update.
Old Oct 5, 2003 | 11:38 AM
dstarrington
temp. guage
I have been thinking about this for a few minuets, and if the themostat is stuck open then the gauge should read and stay between 1/4 to 1/3. But it doesn't even move into the normal zone. I think I will replace the themostat anyway, you have to start somewhere.
Old Oct 5, 2003 | 11:53 AM
marragtop's Avatar
marragtop
Have you verified that the gauge is ok by grounding the wire?? Keep in mind that the fan also plays a role in cooling the engine which may help explain why it doesn't get into the normal range.
Old Oct 6, 2003 | 05:20 PM
dstarrington
where is the sending unit located? Any diagrams would really help? Thanks for all the support!
Old Oct 7, 2003 | 09:00 AM
marragtop's Avatar
marragtop
Sending unit is located on the front of the intake manifold.
Old Oct 13, 2003 | 10:40 AM
dstarrington
fixed
This weekend I replaced the thermostat and found that the old one was stuck open. After replacing I started the truck and within two minuets it started warming up! GREAT! Thanks everyone for all the help.
Dustin
Old Oct 23, 2003 | 08:27 AM
Bullitt's Avatar
Bullitt
Post
Gentlemen
I recently bought a 1997 Ford Explorer with V6 and noticed on the way to work this morning that the temperature gauge was not working.
The original poster indicated he put in a new thermostat and it warmed up, but never indicated if the gauge started working correctly. My Explorer warms up fine and puts out toasty heat.
Not sure if it's the sensor or the thermostat.
Gut feeling says sensor, and I understand there's a service bulletin out by Ford on this (#99-23-4).
Just looking for ideas.
Thanks
Old Oct 23, 2003 | 04:13 PM
87 XLT's Avatar
87 XLT
Bullit, in your case it sounds like the only problem is an incorrect temp gauge reading. As mentioned earlier, try grounding the sending unit wire, if the gauge pegs at full hot, replace the sending unit.
Old Oct 23, 2003 | 09:20 PM
Bullitt's Avatar
Bullitt
87 XLT
Thanks
Thought it might be. Will test tomorrow.
Bullitt
Old Oct 24, 2003 | 09:10 PM
Bullitt's Avatar
Bullitt
Thanks guys. Replacing the temperature sending unit did the trick. Gauge works fine now.
Thanks for the help.
Bullitt
Old Oct 25, 2003 | 12:20 AM
87 XLT's Avatar
87 XLT
Bullitt, thanks for the pdate,glad to hear you got it fixed
Tobyboy78
Dec 21, 2015 10:59 PM
Irishmc33
2004 - 2008 F150
Apr 2, 2015 05:05 PM
JHarsh
21
Dec 2, 2014 08:17 AM
pfitz
Aug 11, 2003 10:23 AM
