Adding coolant
Old Jun 24, 2019 | 01:05 PM
jed1894's Avatar
jed1894
I took the fleet charge back. Now I am really confused. Without reading 20 pages of research, what can I safety put in my 01 7.3? Preferably something I can get somewhere other than ford. I work all day and can’t get to dealer. And by the way, I called 3 dealers and got 3 completely different answers on what to use. Jeez
Old Jun 24, 2019 | 01:35 PM
greg_8507's Avatar
greg_8507
As I said, the stuff you had was the right stuff, but this is better and I got it from TSC.
Rotella ELC
The easiest spec to look for is Caterpillar EC-1
Does not have to be Rotella brand, there are other manufacturers.
Old Jun 24, 2019 | 03:55 PM
jed1894's Avatar
jed1894
Advice
Ok guys. Picked up some Final Charge today. Here’s the question. When I checked yesterday, I added 1/2 gallon of distilled water to bring it to cold fill. Ran all day (about 200 miles) in 97 degree hot southern weather. Temp ran cool and AC ran fine. So, I checked it today and noticed I’ve lost about a quart (I’m guessing). You think it just pulled more into engine block, etc?
The oil is at same level and very clean. I see no leaks around thermostat, hoses or anywhere. Everything looks dry as a bone. So, unless I have a tiny hole somewhere, I’m stumped. Any ideas?
2nd question. From drawing some fluid out, it looks gold/yellowish but the eater may diluted green. It’s almost water color. So, I was thinking of adding some antifreeze. I have the final change and regular Prestone stuff. Or should I add more distilled water?
Also, I’m assuming I should wait on flush until I figure this out.
Thanks in advance. JED
Old Jun 24, 2019 | 05:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do not mix colors. Just add water of you need to buy time.
ELC (the red stuff) is the best you can get. Ford won't tell you that because it's not what is designed for it, but it's the best.
Old Jun 24, 2019 | 05:23 PM
jed1894's Avatar
jed1894
Got the ELC today. I will add more water and see if it levels off ... where could be going ?
Old Jun 24, 2019 | 05:36 PM
greg_8507's Avatar
greg_8507
I once had a leak on the flange that bolts onto the water pump and connects to the lower radiator hose. It took me forever to pin point it because the leak was so small it seemed to be drying up as it was leaking. I only found it after the o-ring between the flange and water pump failed completely. After that the coolant level in the reservoir seemed to settle maybe an inch below the cold mark. If I topped it off, the level would go back down, but when I left it alone, it stayed for well over a year before I needed to top off again. Then here recently when I couldn't pin point a pretty good leak I got some UV leak detector and a UV flashlight. Then all the oil that was dripping down around the oil pan and everywhere else started glowing, and I found a crack in the block right above the oil filter.
Old Jun 24, 2019 | 11:34 PM
'88 E-350's Avatar
'88 E-350
If your truck has a trans cooler in the radiator check the ATF to make sure it's not going there. Not likely, but if it is going to the trans an immediate trans flush is in order.
Old Jun 26, 2019 | 09:06 PM
jed1894's Avatar
jed1894
Well guys I did the flush today. Interesting note.... this thing had no antifreeze.... maybe just a tad but it was mostly water. Very clean but just clear water.
Did the flush and all seems good. I will see if I’m loosing any anywhere now.
On another note. My AC has been cycling to warm blow occasionally... I thought it was the clutch issue I was going to fix next. Think the lack of antifreeze has anything to do with AC not blowing cold?
Jed
Old Jun 26, 2019 | 09:20 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It's technically possible, but I don't think it is. There is always hot coolant (or in your case water) running through the heater core even if the heat is off. The air is not directed through the heater so it doesn't get hot, but the radiant heat can raise the air a few degrees.
Some Rangers and Excursions came with a valve that redirects this fluid from entering the heater core when MAX A/C is selected. you can do this as a simple mod, but as I said I really don't think this is going to be the cause. It seems unlikely that it would have that profound of an effect.
Does your AC compressor cycle on and off frequently? Does it run at all? Does it not get cold at all?
I have attached a few videos I think might be relevant.
Old Jun 26, 2019 | 09:26 PM
jed1894's Avatar
jed1894
Thanks for videos.
The AC runs cold 95% of the time. Occasionally, it will blow just air for about 3 to 4 minutes. It always comes back to cold. I did measure the gap on the clutch and it’s .050. So, I am assuming that’s my problem.
Old Jun 27, 2019 | 08:23 PM
jed1894's Avatar
jed1894
Well guys.... listen to this:
i started up the truck today to drive to store with new, top-off Final Charge. Got to the store and it’s leaking like a water hose from somewhere under the water pump. I hurry home to drain the high-dollar antifreeze (still leaking). Put water back in so I can maybe take to mechanic. Start it up, it leaks water for just a minute then stops leaking. The water is holding its level with no leaks. What the hell?
Keep in mind, it did not leak before (or at least anything I could see on driveway.). I’ve only added about a gallon or so of distilled water since I’ve had it. But it was leaking antifreeze at a rate that I didn’t think I would make it home. It was leaking just as much as when draining from drain tube. Probably lost a gallon or so in a two mile trip.
Any ideas before I take it somewhere????
thanks JED
Old Jun 27, 2019 | 08:34 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
thanks JED
Very suspicious for a bad waterpump. There is a weep hole in the waterpump that will start leaking when it fails. Pretty common. In my experience the waterpump only last about 150k miles. The red coolant also makes it easier to find the leaks.
My recommendation is to drain the coolant, put a new water pump on, add a coolant filter (you can either get a kit or a water pump from International with a filter housing built in) and re fill.
The 7.3L from Ford didn't come with a coolant filter because it was intended for more consumer use. When International sold the 7.3L as the T444E they included a coolant filter because commercial vehicles tend to get more reliable service. Only makes sense to add one since the manufacturer did.
Old Oct 14, 2022 | 11:08 PM
  #28
Stevensonb1120's Avatar
Stevensonb1120
3rd Gear
Great read I'll keep you posted how my 04 turns out with red final charge. Bought this truck for 5k and hobbled it home. Didn't diagnose it much. Was told it wad leaking oil from oil cooler. It had no antifreeze during teardown....
Old Oct 15, 2022 | 01:47 AM
  #29
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Best of luck with the coolant!
Since that's a 6.0 and not a 7.3 engine most folks here will not have the chops to answer your questions. Hopefully a moderator can move your posts to a 6.0 forum to get wiser eyes on it.
@redford @Y2KW57
Old Oct 15, 2022 | 01:25 PM
  #30
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
He has already posted in the 6.0L forum, so I will let his post here stay here.
GeneLaw1
Oct 15, 2022 10:37 AM
superduty91
6.7L Power Stroke Diesel
18
Jul 1, 2015 09:50 AM
Tom
Mar 6, 2011 08:08 PM
EBSTEVE
Jul 28, 2005 09:54 AM
fhartell
Jan 1, 2004 06:44 AM
