Code: P1690 - Wastegate Solenoid
Hello All
I just purchased a 2000 Excursion 7.3. The day after I purchased it the engine light turned on and the truck ran rough. I had the code read and it came up as 1690 Wastegate Solenoid. I purchased a new Solenoid and it ran fine for a few miles with no light. The next time I ran the truck the light was back and it ran rough again. I don't know much about diesel trucks so any help would be appreciated. THanks
Did the same code come up again after you changed the solenoid and then cleared the code, or did you not clear the code after you changed it?
The solenoid won't make it run rough. Like mentioned earlier, probably the 42pin rubbing on the ds valve cover, or even a loose uvch connection. Also pull the icp sensor plug (on the drivers side head) and check it for oil. Those cost nothing but your time to check
Rather than paying someone to read codes, get TorquePro or Forscan smart phone apps and a WiFi or BlueTooth OBDII adapter. WiFi is for I-Phone, BlueTooth for Android. Or give us your location. Maybe one of us can come and read it for you. The smart phone apps are cheap and will pay for themselves very quickly.
I haven't figured out the check engine light code yet. I've looked for any chafed wires and can't find any. When I turn the key to the on position without starting the engine this part clicks Non-Stop. Can someone help me identify this part? Is this part supposed to click prior to the engine? I will look into purchasing software in the future to read codes. I really appreciate all the help.
I haven't figured it out quite yet. I installed new headlight lenses today with LED bulbs but the brights don't work so that adds to the list of what I need to figure out. I did check all the wires, the UVCH and the icp and all looks good.
I will check how the truck runs with the wipers on. In regards to the Wastegate I didn't notice the boots looked old, perhaps those need replaced. I did unplug the Wastegate when the engine was running and I didn't notice any difference in the sound of the engine.
