Fuel filter housing replacement heater hook up question
I have a 1985 f250 I was wondering how to hook up the heater for https://www.allpointsmarineco.com/racor-445r-445r12-445r24-series-diesel-spin-on-filter-separators-w-heater.html housing I was thinking about hooking it to the glow plug relay any advice is appreciated
Not that the heater is important at all as long as your temps are above the CFPP of the fuel you are using - so as long as you get winterized fuel in the truck before it gets below about 20F, or use the block heater, you'll be fine. I've had mine deleted for a few years now.
Looking at the diagram above, whenever the key is on.
I still have the old inline Heater along with the Heater in the Filter/water separator Assy ... both are disconnected right now but can be plugged in real quick if needed.
it's also my understanding that you need the run the heater at least 5 minutes before start when you in Cold Country.
there are 2 types of heaters used one style is on the line that goes from the Lift Pump to the filter housing the other style is in the top of the fuel filter housing.
the Line style heater was more common in the 6.9 older IDI engines and a few early 7.3 IDI engines most have been changed to just the one in the top of the filter housing.
they didn't come from the Factory with 2 heaters.... someone before me changed the Filter Housing to a later model, this is why I have 2 fuel heaters, but I don't need em in South Texas. so I disconnected them.
and yes turn on the ign so the heater can heat the fuel 5 minutes before start, as the fuel is cold to start with and the idea is to warm it up before starting.
mine are disconnected right at the plugs... the one on top of the filter housing Oval shaped Black connector with Red/Green wire and the inline is disconnected with a spade connector into the same harness with a Red/Green wire.
I would take that 5 minute time with a grain of salt, it's just been preached so many times at the Stealerships but I have never seen it in writing in any of the Owner's manuals, but it does make a bit of sense is Sub Zero weather.
Will do now I just gotta find a place that will take PayPal credit so I can financing it house building kills the wallet lol
