C6 leaking question
Old Jun 22, 2019 | 03:19 AM
Jghake's Avatar
Jghake
C6 leaking question
I have the engine out of my truck right now and there is fluid in the bellhousing from the transmission. It's been leaking for some time now but it's hard to tell where. I have a new input shaft/torque converter seal, a new trans pump oring, and a trans pump gasket. I figured while I can sit on the cross member and work I might as well.
My question is, if I take out the pump am I going to regret it? How easy is it to get back in?
Old Jun 22, 2019 | 06:57 AM
Franklin2's Avatar
Franklin2
I have never had the pump out. I do know if the engine is out for any period of time, the torque converter seal should be replaced, even if it's fairly new. It should be replaced right before the engine goes back in place. Without the engine supporting the torque converter, it lays on the seal and can deform it and can cause it to leak.
Old Jun 22, 2019 | 09:31 PM
Jghake's Avatar
Jghake
I'm afraid the clutch pack is going to shift on me... Will/can that happen? Any pointers?
Old Jun 23, 2019 | 06:38 AM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
This might help
I have used the contact link here and he answers questions ... Should have your answer Bad Shoe Productions How To Video Series - Ford Transmissions & Rears
Might also ask the guys in the 73-79 forum as they have seen a lot more C6 transmissions ...
Another helpful forum on the C6 http://fepower.net/simplemachinesfor...p?topic=2316.0
Jghake
16
Aug 18, 2019 08:49 PM
JRB65
Feb 1, 2013 10:53 AM
CowboyFromHell
Feb 27, 2010 03:34 PM
fixingbus
Aug 5, 2007 06:11 AM
pauleepee
Sep 13, 2003 06:49 PM
