85 f250 mystery part question
Old 06-10-2019, 06:54 PM
Dillweed73
Dillweed73 is offline
Dillweed73 is starting off with a positive reputation.
Hey guys,
Quick question for all you experts out there,
i have an '85 base model f250 2wd 4 speed granny low that originally had a 2bbl on it. Always sounded like I had an exhaust leak even after I put headers on and I noticed this broken pipe with air coming out of it that is the source of that sound. It's bolted to the back of each cylinder head and t's off in the middle. What does it do and is it needed? Can the now open ports (I removed the piece in question) be blocked off?
Thanks in advance for all the help!
Old 06-10-2019, 08:46 PM
whisler
whisler is offline
whisler is gaining momentum as a positive member of FTE.whisler is gaining momentum as a positive member of FTE.
That part connects the Thermactor system to the back of the heads. The holes in the back of the heads can be plugged with 5/8-11 bolts cut to 0.40 inches in length. Use a copper washer of the correct size to ensure proper sealing. Hope this helps.
Old 06-10-2019, 09:42 PM
kr98664
kr98664 is online now
kr98664 has a great reputation on FTE.kr98664 has a great reputation on FTE.kr98664 has a great reputation on FTE.kr98664 has a great reputation on FTE.kr98664 has a great reputation on FTE.
Please see post #20 here for an excellent description of the thermactor (air injection) system:
https://www.ford-trucks.com/forums/1...l#post18618032
Also see post #27 in that same thread for my experience, basically the same as yours.
Old 06-11-2019, 01:18 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by Dillweed73 View Post
Here's an example of the little darlin' .. 351W will be similar to 302.
Old 06-11-2019, 04:43 PM
kh0432
kh0432 is offline
kh0432 is starting off with a positive reputation.
I had the same problem with my 86 F150 with 5.0L fuel injection. I've already deleted most of the emission controls. The holes in my head don"t appear to be threaded so I made a gasket out of asbestos gasket material to block off the hole. Would the 5.0 heads take the same 5/8 bolt?
Old 06-12-2019, 07:21 AM
Olds64's Avatar
Olds64
Olds64 is offline
Olds64 is starting off with a positive reputation.
That's an excellent write-up.
To the OP, be aware that removing the thermactor can be risky if your still running catalytic converters (as the linked write-up mentions in one of the last paragraphs).
Old 06-13-2019, 07:11 AM
jackietreehorn's Avatar
jackietreehorn
jackietreehorn is offline
jackietreehorn is gaining momentum as a positive member of FTE.jackietreehorn is gaining momentum as a positive member of FTE.
Old 06-18-2019, 08:49 AM
Dillweed73
Just want to thank all you guys for replying,
I ended going with what Whisler posted, cut some bolts down and plugged the holes and the exhaust leak sound went away completely. My trucks been stripped of all emissions equipment including the cats so that thermactor pipe was just sitting there broken with the rubber hose not connected to anything.
Again I want to thank all of you for the help!
Old 06-23-2019, 12:13 PM
kh0432
kh0432 is offline
I previously asked if the 5.0 L had the same size tread where the A.I.R. tube goes. It is a 5/8 18 like in the 351. I couldn't get the bolt started before because of all the carbon in the hole. I couldn't fit a tap between the firewall and head so I cut the tap down and ground the sides so iI could turn it with a short 7/16 wrench. Not easy to access but it is doable. Once the treads were cleaned out it was no trouble putting in the bolts. Laid a piece of plywood on top of the engine and radiator support to have something to lay on. A cut out tennis ball works pretty good to keep from getting jabbed from the hood catch. Other than the catalytic converter and oxygen sensor the are no other emission parts on my truck. Runs really well and is quiet now that all the exhaust leaks are plugged.
Old 06-23-2019, 01:07 PM
kr98664
Oh sure, the simple 30 second solution that works perfectly...
Or if one prefers to overdo anything and everything:
https://www.ford-trucks.com/forums/1...ab-me-not.html
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
