Solid Lug Nuts
Old Jun 21, 2019 | 12:03 PM
brick1's Avatar
brick1
Solid Lug Nuts
Any recommendations for solid lug nuts for my 2018 F250 with factory 20’s? Original nuts are deformed after 15,000 miles and one rotation. Dealer will replace under warranty, but they only have the factory nuts that are clad, which is causing the issue to begin with.
Oh, and my SD came with the wrong lug nut wrench. Found out the hard way...
Old Jun 21, 2019 | 12:53 PM
seville009's Avatar
seville009
I use the spline lug nuts. Solid grip, no stripping.....
keep a breaker bar with the proper socket too; makes it easy to get off if necessary
Old Jun 21, 2019 | 01:09 PM
spongecop's Avatar
spongecop
Semper Fi
Old Jun 21, 2019 | 01:37 PM
D3thM3tal's Avatar
D3thM3tal
Those look nice, anyone use those? I noticed during my FIRST rotation, so this is the first time I've even put a lug wrench to my lugs, that a lot were deformed and it looked like on some the socket slipped off and twisted the tops slightly. Not impressed, but I know since the 00's that they have those crappy style lug nuts.
Old Jun 21, 2019 | 01:42 PM
Dockmaster1's Avatar
Dockmaster1
I have two F350's and both have the splined lug nuts. I am very happy with them. The older of my two trucks has had the wheels off/on numerous times with no issues.
Old Jun 21, 2019 | 01:50 PM
spongecop's Avatar
spongecop
Semper Fi
yes, put them on my sons 2013 F150.....will put on my 2017 when the time comes.
Old Jun 21, 2019 | 01:53 PM
D3thM3tal's Avatar
D3thM3tal
Good deal, thanks. They don't give them away, but it's cheap insurance.
Old Jun 21, 2019 | 03:49 PM
DSLTRK60's Avatar
DSLTRK60
Mcgard also makes nice aftermarket and oem lug nuts. Plus they have a lifetime warranty if the Chrome fails.
Plus they are forged in USA and support our economy.
Old Jun 21, 2019 | 06:41 PM
seville009's Avatar
seville009
Problem with the chrome is they can round off and be stuck on. Warranty is useless when you’re sitting there trying to get the tire off.
Had one round off on me; all just using hand tools. Luckily was able to finesse it off. Had it happen a few months ago on a different car - luckily was trading it in within a month so I just left it on.
Old Jun 21, 2019 | 08:20 PM
DSLTRK60's Avatar
DSLTRK60
The Chrome is a few thou thick over hardened steel on these. I guess they could round if the wrong size was used or there was little engagement from the socket.
Old Jun 21, 2019 | 09:22 PM
KCJackson1's Avatar
KCJackson1
Put a set of McGards on my 96 Ram. They were terrific, and looked great. Couldn't use the factory lug wrench on them so I also bought a nice big "X" iron with multiple heads. The reason they're warranted against rust (or at least the reason mine were in 1999 when I bough them) was because they weren't traditional chrome - they were polished nickel, which won't oxidize in normal conditions.
Old Jun 21, 2019 | 10:18 PM
12Farmer's Avatar
12Farmer
What is the McGard part number for their OEM lug nuts that will fit a 2018 F350? I already have their locking lug nuts using the flat seat (1 per wheel) and don't want 7 more of those on each wheel.
Old Jun 21, 2019 | 10:32 PM
willynilly's Avatar
willynilly
meh. those are just one year warranty it looks like. mcgard are lifetime. theyre not cheap but if you want the best of the best just get mcgard
Old Jun 22, 2019 | 10:57 AM
D3thM3tal's Avatar
D3thM3tal
That Amazon link points to M14x2.0 lugs and searching on McGard you get pointed to M14x1.5.
I'll probably get a rotation or two out of these before I deem them junk.
[***************]M14 x 1.5[/color]
Old Jun 23, 2019 | 02:59 PM
Chrislorl6211's Avatar
Chrislorl6211
It looks like the chrome version of the lug nut at amazon and at DP Accessories is no longer available. Anyone have any other info?
