Would the Idle Validation Switch throw a code?
Old Jun 20, 2019 | 07:54 AM
jackstraw's Avatar
jackstraw
Have had a couple instances of a 0.1 second hesitation in the idle this morning, and one yesterday.
Finally on the third one, the Service Engine Soon light came on.
Last fall, I had the IVS flake out. Truck would start and run perfectly, but no response from gas pedal. I took the pedal apart, cleaned it and used a wire brush some, and re-installed the same one and problem went away.
I bought an extra pedal at a junkyard, and my first thought was to now swap that one in.
But now with a brand new code stored, I wonder if an IVS issue would throw one?
I can’t pull the code until late afternoon.
Old Jun 20, 2019 | 08:26 PM
Colorado350's Avatar
Colorado350
Yes it will. P0220, P0221.
Old Jun 22, 2019 | 11:03 AM
jackstraw's Avatar
jackstraw
Another Thanks!
Knowing the exact codes was a big help.
So far that IVS problem I ran into last Fall was one of the simpler fixes I have ever done on a vehicle.
But with a new round of IVS trouble a looming possibility, that was my first hope/thought out in the woods the other day.
It took a minute to get some codes out - ODBII scanners have never liked my truck. Turns out, fuse #3 was blown, again - it runs just the cigarette lighter (so I just use the upper power point), and power for the ODBII port, and nothing else. So tough to notice in daily life. I think a bare/dirty/loose wire in the lighter port is routinely blowing that fuse and should be a simple fix.
Old Jun 22, 2019 | 11:05 AM
jackstraw's Avatar
jackstraw
Since I can't edit a thread title, I will start a more accurate one on my next hopefully small fix....
Stetson Bryant
Jan 8, 2019 05:19 PM
qadash
Modular V10 (6.8l)
Jul 24, 2013 06:06 PM
swillett
1997 - 2003 F150
Oct 30, 2012 07:33 PM
Spank226
Oct 19, 2010 04:41 AM
BeauHymel
Aug 31, 2009 09:40 AM
