Sponsored by: Auxito
Windows 10
Old Jun 19, 2019 | 11:49 AM
NW Viking's Avatar
NW Viking
Unhappy Windows 10
Has anybody had trouble using their Ford 1997 Truck Service Information after installing Windows? It worked on XP but will not run on Windows 10. The disk is a Frod Product.
Old Jun 19, 2019 | 07:05 PM
steve(ill)'s Avatar
steve(ill)
The old disc was not made for the new version of Windows... Normally there is a section called "PROGRAMS AND FEATURES" ... it might be in "CONTROL PANEL"..... from there you can tell the computer to try to open your program with an OLDER version of Windows......... it still uses W10 , but simulates Win7 or XP, etc.
Old Jun 20, 2019 | 09:16 PM
projectSHO89's Avatar
projectSHO89
Most likely, the disc is a 16-bit application and the Windows 10 system is a 64 bit version. Won't work.
You can install an XP system in a virtual machine and it should work in that environment. I had to do that on my last laptop so I could have my 92-95 service libraries online. Now, I just keep them on an old XP machine set up in the basement as those are rarely needed.
Old Jun 22, 2019 | 05:29 PM
ncranchero's Avatar
ncranchero
Same here. Simplifies things
rla2005
13
Feb 1, 2018 12:35 PM
MIKES 68 F100
Aug 4, 2015 02:53 PM
Headviking
Feb 21, 2014 09:29 AM
sand_fiend
Jan 4, 2013 01:04 PM
beartracks
Dec 30, 2009 07:32 PM
