I used a 1500 lumen flashlight in total darkness and didn't see any cracks. I filled it to the top with water and let it sit overnight and it didn't lose any.
Granted, no pressure is being applied. Outside of taking it to work and performing a dye penetrant inspection that is all I have done and found nothing.
I have always torqued the cap to spec but I admit the torque is rather low as after all, it is a plastic cap. Oil on the O-ring always. I believe that somehow the plastic fingers let go in the final or next to final revolution of the cap. And with my luck that makes perfect sense.
I could be wrong but I’m guessing the issue (besides the oil filter stem breaking) was the oil leaking from the cap, especially since you mentioned the underside of the hood being coated. And since that’s what you replaced and the oil doesn’t seem to be leaking anymore...
Maybe an aside, but I find 13-14 quarts good for my engine, 15 liters is way too much for it.
I think he mentioned 15 quarts, not liters. Although I put in 14 quarts at oil changes, 15 quarts isn’t excessive. 15 LITERS, however, may indeed be a bit much...that’s the better part of 4 gallons 😳
You're right, once I start writing I can't go back to the post and check. Still shouldn't cause leak, but not good to overfill. halfway between min and max makes it easy to see when/if things start happening
Hey guys. No road tests yet but from my leak tests the starting time is getting better (as was mentioned, purging the air). Still no leaks. I have not had a chance to check the old cap yet.
Thanks again for all the replies. They are appreciated!
