Power Steering Hoses - Slightly Different Question
I have an E99 and have found the wear spot from the shock tower on the power steering pressure line from the pump to the hydroboost and am getting ready to change that hose. This leads to a couple of questions - I see a lot of discussion about people having issues with this hose and the fitting on the pump coming apart leading to repeated replacements. However, I do not really see any discussion about the other pressure hose from the hydroboost to the steering box. Is this hose not much of an issue? I have thought about changing both of the hoses since I will be in there anyway. So what is the general consensus on the importance of this other hose?
Second, what is up with the pricing on this hose? I can get the pump to hydroboost hose at a reasonable price but the other hose is very UNreasonably priced - I see it running in the $175 to $225 range for this simple hose.
Anyway looking for thoughts on this whole situation. Thanks for the feedback.
I did replace the low pressure hose, but only because I was in there replacing the steering gear and other hose, so I figured get it out of the way. I also wrapped the high pressure hose with a split 1" reinforced fuel line from TSC. I wrapped the 1" line well before and after the contact point on the shock tower/bracket.
If you do go with the "cheaper" lines from whatever X brand, make sure you get the teflon washers that go on the hoses on the gear side.
Dorman 82540 available at any parts store.
I have seen the forum post that describes the "reduced noise" hose and I guess that is a possible contributor to the high cost - who knows.
I am thinking about a Gates brand hose as a medium ground between the no-name and Motorcraft - any specific feedback on the Gates product?
Anyway, I think right now I will skip the hydroboost to gear hose and just work on the pump to hydroboost hose.
Wire loom to protect rubber hose portion along the frame and shock tower would be a good idea.
The OEM hose has a swivel nut the is separate from the hose. The nut has a snap ring inside it. It is intended to swivel after it is tight. The nut was threaded into the pump first. As the trucks went down the assembly line the hose was pushed into the nut and the snap ring keeps it together. Quick and easy to get as many trucks built a day as possible.
Over the years the snap ring itself, the snap ring groove in the nut, and the snap ring groove in the machined fitting at the end of the tube all wear. Under normal operation this is usually not a problem. The problem"usually" occors when you unscrew the nut and reinstall it. Now you have parts that have worn together for years and once back together the snap ring fails allowing the nut to come off the machined fitting.
The connections without a snap ring usually do not fail in this way. Also inside the nut is an o-ring to seam but the snap ring keeps it assembled.
Edit I made it about 10 feet after my engine swap trying to reuse the old hose as I forgot to pickup a new one.
Also, I am not sure the fittings noted in the thread below would be of help, but I figured it couldn't hurt to list it here. This link was taken from the 7.3L PSD Tech Folder.
Also, I am not sure the fittings noted in the thread below would be of help, but I figured it couldn't hurt to list it here.This link was taken from the 7.3L PSD Tech Folder.
Thank you. I'll reach out to them. Right now I have:
1) 1999+ Pump to Hydroboost
2) Custom(?) Hydroboost to Gear
3) 2008 (or 1999) Gear to Cooler
4) 1999+ Cooler to Pump
