6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
HELP
Old Jun 16, 2019 | 01:17 PM
William Davis's Avatar
William Davis
HELP
Bought this and heard a chirp noise, salesman said it was an easy fix. I know lying. Anyways it was a small chirp at first. Usually when driving operating temp. Figured I would swap out the tensioner pulley, replace belt, and replaced 2 idler pulleys. After doing that it seems to have gotten worse. When running between 1,500-3,000 rpms it just squeals god awful loud. It seems with each new part it gets worse. Can anyone give advice on what to do next?? I am lost at this point
Old Jun 16, 2019 | 06:15 PM
m-chan68's Avatar
m-chan68
Exhaust manifold leak?
Old Jun 16, 2019 | 08:46 PM
Fefanatic's Avatar
Fefanatic
The first thing I would do is pull the belt and run it again. If the noise is gone then you know it's up front and need to look further. I bought one that had a loud squeal and I thought it was turbo. Turned out to be broken exhaust bolts on back of manifold driver side. While it may be able to repair in the truck I would recommend a cab pull to repair it. I had a heck of a time drilling broken bolts with the engine out and on a stand. Wound up having to tap a bigger bolt into the hole.
Old Jun 26, 2019 | 10:33 AM
73fan's Avatar
73fan
I have also seen the gasket between the two turbos fail and cause exactly what you describe. I had an assistant put some load and RPM on the engine while I moved my stethoscope around until I nailed it down.
Old Jun 26, 2019 | 10:53 AM
Firefighter 1406's Avatar
Firefighter 1406
You can get a loud screech from the turbo also. My truck would do it when you got on it. Exhaust manifolds or up pipes are defiantly possible also.
pmkitchen
Nov 30, 2015 06:28 AM
Ziob
Nov 16, 2015 09:08 AM
countryboy73703
43
Feb 17, 2014 06:44 PM
68dutchguy
Mar 26, 2010 08:36 PM
xcopterdoc
Nov 26, 2002 10:10 AM
