4R100 controller (without a Ford engine?)
Old Jun 15, 2019 | 11:42 PM
apostate's Avatar
apostate
I'm here to learn about being a powertrain apostate so here goes...
I don't know much about Ford transmissions, or the computer control modules related to them. But assuming I wanted to use the computer controlled 4R100 transmission with something out of the ordinary (anything from a carbureted gas engine to a mechanical injected diesel lets say, it shouldn't really matter - I have interests in this transmission beyond just one project actually) is there a way to do this with a factory Ford ECU or is my only option one of the fancy $2000 aftermarket controllers i've seen for sale?
Old Jun 23, 2019 | 06:33 PM
Blurry94's Avatar
Blurry94
The stock ECU will need, at the very minimum, vehicle speed and throttle position for it to operate the transmission properly. RPM's do play a small role but but they are mostly referenced for heavy throttle/WOT operations.
Old Jun 23, 2019 | 07:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The stock controller does need to see engine RPM to work properly.
Old Jun 22, 2020 | 12:12 PM
Bigjohn80's Avatar
Bigjohn80
Transmission computer
Where is the “stock controller” located? Part of the PCM itself?
Old Jun 22, 2020 | 03:30 PM
Mark Kovalsky
Yes, it is part of the PCM.
DIYiT
Sep 5, 2013 09:04 PM
godblessmud
General Automotive Discussion
Aug 8, 2007 03:19 PM
cindyj578
Aug 21, 2005 02:46 PM
DALPILOT
Aug 31, 2004 12:04 AM
luke_trash
Jul 15, 2003 12:38 AM
