temperature probe port
Old Jun 15, 2019 | 02:43 PM
dustyroad's Avatar
dustyroad
I'm looking for a port to add an aftermarket temp probe. on my 86 460
The only one available I see is behind the distributor to the left.
If that is an actual spot coolant flows thru. I'm not sure it looks like it could be.
Any other open spots easily accessible? The spot on my 79 I used is being used by I'm assuming the factory gauge.
The other option is cutting a hose and using a sensor attachment. Probably would be the easiest.
Not sure if I want to go that route because of it being dependent on thermostat.
They don't make a heat core hose attachment for probes do they?
The port on the block looks like a lot of soaking with penetrating oil.
Old Jun 16, 2019 | 10:40 AM
dustyroad's Avatar
dustyroad
Since it seems only crickets are here I'll share this with them.
Found a heater core hose sensor adapter, probably will use that.
Old Gal
Jan 7, 2015 12:26 AM
tobyw
Jul 13, 2007 10:33 PM
tobyw
Jul 10, 2007 10:47 PM
davdogg39
1978 - 1996 Big Bronco
May 19, 2005 01:47 PM
GeneStoner
Apr 25, 2003 01:51 AM
