Sponsored by: Real Truck
What is this part called?
Old Jan 6, 2015 | 09:08 PM
Old Gal's Avatar
Old Gal
Hi, can anyone tell me the name of this part? (no. 1 in attached image).
It connects a heater core hose to the IAT sensor and Thermostat Housing.
Thanks for any assist!
Old Jan 6, 2015 | 09:12 PM
05F250DSL's Avatar
05F250DSL
If that is a coolant line that cannot be the inlet air temp sensor that would be a coolant temp sensor. Even tho I have owned two straight 6 f250's I am by far an expert on them.
The bigger part is the water outlet. I would call it
Either heater hose outlet o heater hose connector
http://m.autozone.com/autozone-mobile/en/parts/1990-Ford-F250-3-4-ton-P-U-4WD/Water-Outlet/_/N-iu3kpZ93xm0?searchtext=Thermostat+housing
Old Jan 6, 2015 | 09:22 PM
Old Gal's Avatar
Old Gal
I am not experienced enough to disagree about the sensor. You may surely be entirely correct.
I had 'googled' the part number showing on the sensor and it was identified as AIT Sensor... it however is not my main concern...
Can you, by any chance, tell me what that piece is called that the sensor screws into and attaches to the heater core hose?
I ordered a new thermostat housing and I want a new 'what ever that is' as well.... but I do not know what to call it, in order to search for the best deal on price.
Old Jan 6, 2015 | 09:31 PM
05F250DSL's Avatar
05F250DSL
Heres a thread with a part number
https://www.ford-trucks.com/forums/726686-water-outlet-pipe.html
Old Jan 6, 2015 | 09:42 PM
Old Gal's Avatar
Old Gal
THANK YOU!
Old Jan 6, 2015 | 09:48 PM
Old Gal's Avatar
Old Gal
That certainly makes sense... "Water Outlet Pipe"... thanks again!
Old Jan 6, 2015 | 09:59 PM
Old Gal's Avatar
Old Gal
Thank you. I appreciate the response!
Old Jan 7, 2015 | 12:26 AM
Old Gal's Avatar
Old Gal
YEAH I FOUND IT!
It is called simply a 'heater hose fitting'... and the Ford part number is now obsolete... but some are still available... but not many... it is :
heater hose fitting D9TZ-18599-A
They no longer are making them... so it is a hefty cost factor... compared to what I paid for a new thermostat housing.... as I got the new part for $43, which includes $8 for shipping. In light of the fact that the original piece lasted 24 years... suggests that investing in a new one is not that bad a deal, really.
Hope this helps others looking for this rascal.
dustyroad
Jun 16, 2019 10:40 AM
Supercab
Dec 29, 2014 03:43 PM
bjolie
Dec 1, 2004 11:42 AM
yoda
Mar 14, 2004 06:55 AM
GeneStoner
Apr 25, 2003 01:51 AM
