Battery Cable Removal
Old Jun 13, 2019 | 09:51 AM
mtnguy's Avatar
mtnguy
The drivers side positive battery post and clamp has corroded, and I would like to remove the cable to clean that puppy. Can I use a jumper cable from the other battery positive post to the driver side cable so that I don't loose power to the computer during removal ?? Thanks in advance.
Old Jun 13, 2019 | 09:55 AM
djousma's Avatar
djousma
You can just remove it. The other battery will still provide power to the truck electronics.
Old Jun 13, 2019 | 11:30 AM
Just Strokin's Avatar
Just Strokin
Just make sure you do not allow the driver's side cable ground to the chassis as it will still have 12vdc on it.
If you need to remove the battery, I used a bungee cord to suspend the positive cable on either side to the hood so neither will ground out.
Old Jun 15, 2019 | 07:09 AM
mtnguy's Avatar
mtnguy
Many Thanks !!
Old Jun 15, 2019 | 10:34 AM
HRTKD's Avatar
HRTKD
For what it's worth, the owner's manual does address this and says what djousma posted.
sgip2000
Jan 2, 2016 07:23 PM
Boatbum01
Sep 19, 2010 12:24 AM
whitesdford
Sep 11, 2007 10:03 PM
stupidjet
Feb 4, 2005 06:32 PM
ojosdestranger
1978 - 1996 Big Bronco
18
Oct 29, 2004 01:25 PM
