battery cable replacement
Old Jan 30, 2005 | 12:44 PM
stupidjet's Avatar
stupidjet
i have a 1990 f450 with 7.3...at rockauto.com it says i need 4 cables...totals 142.16...are these the correct part numbers and is there any cheaper place?
<table class="main"> <tbody><tr class="catalogpart1"><td>MOTORCRAFT Part # WC8861
Battery Cables Anti-Corrode Ground Cable; RH {#FOTZ14301B}</td><td class="right">$26.79</td><td class="right">$0.00</td><td class="right">$26.79</td><td class="center"><input type="submit" name="addpart[1]" value="Add Part"></td></tr> <tr class="catalogpart0"><td>MOTORCRAFT Part # WC8862
Battery Cables Anti-Corrode Ground Cable; LH {#FOTZ14301E}</td><td class="right">$29.79</td><td class="right">$0.00</td><td class="right">$29.79</td><td class="center"><input type="submit" name="addpart[2]" value="Add Part"></td></tr> <tr class="catalogpart1"><td>MOTORCRAFT Part # WC8821
Battery Cables Anti-Corrode Ground Cable; Comm. L.H. Side {#E9TZ14301H}</td><td class="right">$36.79</td><td class="right">$0.00</td><td class="right">$36.79</td><td class="center"><input type="submit" name="addpart[3]" value="Add Part"></td></tr> <tr class="catalogpart0"><td>MOTORCRAFT Part # WC8820
Battery Cables Anti-Corrode Ground Cable; Super Duty Comm. Stripped Chassis RH {#E9TZ14301G}</td><td class="right">$48.79</td><td class="right">$0.00</td><td class="right">$48.79</td></tr></tbody> </table>
Old Jan 30, 2005 | 03:50 PM
dave200's Avatar
dave200
Not exactly.......
What you're looking at for your truck is 2 ground cables, a LH and a RH and the positive, which is one piece, connecting both batts to the starter. The listing you gave is for the ground cables, 2 different grades.
Check NAPA, they should be about $100.00 for everything.
Dave
Old Jan 30, 2005 | 05:28 PM
redneckf350's Avatar
redneckf350
got mine from napa was about $120 only took about 30 mins to do the positive cable get some di eltric grease for your terminals well worth the money
Old Feb 1, 2005 | 03:22 PM
RANCHHAND's Avatar
RANCHHAND
Make them out of 2/0 welding cable.It is 600 volt and costs about $2.00 a foot. Then crimp them yourself with new ends. It was under $20 for my positive cable.
Old Feb 1, 2005 | 06:32 PM
ditto's Avatar
ditto
the napa ones are really really nice. i would argue much nicer then the dealers
i think it's also a 3 gauge wire, and not a 4.
Old Feb 1, 2005 | 10:39 PM
cemenacho's Avatar
cemenacho
you guys suggest putting dialectic grease down on the solenoid? where else?
Old Feb 2, 2005 | 01:07 AM
ditto's Avatar
ditto
old wires:
new wires from Napa:
Old Feb 2, 2005 | 08:40 PM
redneckf350
I put the grease anywhere there is a connetion terminals solenoid starter
Old Feb 2, 2005 | 08:42 PM
redneckf350
looks like the old cables off of my truck the pos cable of the pass side rotted in 2
Old Feb 4, 2005 | 11:08 AM
stupidjet's Avatar
stupidjet
are the napa wires dirent replacements or do they make them there or something?
Old Feb 4, 2005 | 03:07 PM
ditto's Avatar
ditto
Napa is an Auto Part's store- i would say the best quality auto store in my area (besides the dealer). and yes it's a direct replacement.
Old Feb 4, 2005 | 06:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
NAPA makes the wires to fit your truck.
The correct wire size is 2/0 between the two batteries
And 3/0 from the passenger side battery to the starter.
You should also have a #4 wire added to the passenger side terminal to replace the wire that goes back to the inner fender starter solenoid or inner fender well glow plug relay depending on the year of your truck. That is the main electrical connection point for everything but the starter.
The one I am refering to is the smaller red wire above the battery in Ditto's top picture.
I would also add a #6 wire to each negative terminal and ground it to the body on both batteries.
ReAX
Modular V8 (4.6L, 5.4L)
Dec 11, 2012 11:56 AM
kingeightclub
Aug 31, 2011 02:29 PM
txgp17
15
Apr 26, 2011 07:50 AM
morrisjl2
General Diesel Discussion
Apr 30, 2009 03:00 PM
indebt
Nov 7, 2008 09:29 PM
