Transfer case fluid
Old Jun 12, 2019 | 09:52 AM
Batgeek's Avatar
Batgeek
Transfer case fluid
Going to be changing out the transmission soon. I know that Mercon V is the approved fluid for the transmission, but what about the transfer case? From what I've read here Mercon V is not approved for the transfer case only Mercon and Mercon isn't made any more, at least not license approved by Ford. Every manufacturer is possibly using their own recipe. So what am I putting in my transfer case that says Mercon? What do you guys use and what is safe? Is there a transfer case fluid approved?
Old Jun 12, 2019 | 09:55 AM
ArmyLifer's Avatar
ArmyLifer
Ford Transfer Case Fluid XL-12. Others have used Mercon V with no issues.
Old Jun 12, 2019 | 10:10 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Mercon V superceded Mercon. So if something says Mercon, it's OK to use Mercon V.
When I changed the fluid in my transfer case on my gasser, I used Castrol Mercon V.
Old Jun 12, 2019 | 10:13 AM
ford390gashog's Avatar
ford390gashog
The XL-12 is discontinued.
Old Jun 12, 2019 | 12:38 PM
Wes444's Avatar
Wes444
Maybe discontinued, but not impossible to find. I drained n filled with XL12 last year
Old Jun 12, 2019 | 12:58 PM
Sous's Avatar
Sous
FTE Emeritus
Used Amsoil ATF for years, recently changed fluids and switched to XL-12 for the transfer case.
Old Jun 12, 2019 | 04:44 PM
Batgeek's Avatar
Batgeek
Thanks for the information. With it I did a little investigating and discovered Ford is recommending Mercon LV for our transfer cases.
https://www.fcsdchemicalsandlubrican...ission%20Fluid
I guess I'll give that a go.
Old Jun 13, 2019 | 04:08 PM
arto_wa's Avatar
arto_wa
I used 2.5 qts. of Valvoline Synthetic Transfer Case Fluid.
Old Jun 13, 2019 | 05:09 PM
brian42's Avatar
brian42
Veteran: Navy
I put Mobil 1 Synthetic ATF in my transfer case shortly after I bought it and only swapped out the fluid once in the 11 years I had it. I never had a problem with the transfer case and I doled out more than enough stress through it as I off-road fairly consistently. I don't do rock crawling but I do get a lot of looks as 4 tons of Ford with a 13' wheelbase is not a normal sight on the trails.
Old Jun 13, 2019 | 06:37 PM
renoduckman's Avatar
renoduckman
Fluid
Yes I also used Mobil 1 ATF last time. At the end of last year I bought Motorcraft transfer case fluid cheap from Rock Auto. Haven't got around to changing it yet but suppose to be the right product.
Old Jun 13, 2019 | 11:06 PM
00t444e's Avatar
00t444e
Regular cheap mercon rated atf is all you need, for the transfer case.
Dads79
2015 - 2020 F150
Feb 26, 2019 08:50 AM
Syncrowave
30
Sep 28, 2017 08:33 PM
96mark8
Sep 28, 2013 01:17 PM
VQT
Apr 29, 2013 08:55 PM
1986fordrangerman
1997 - 2003 F150
Dec 31, 2008 06:02 PM
