Aerostar Ford Aerostar
Jacking
Old Jun 11, 2019 | 12:45 PM
87&97Aerostrar's Avatar
87&97Aerostrar
Jacking
I want to rotate the rear tires to the front and the front tires to rear.
Has anyone ever jacked an Aerostar from the side to be able to do this?
If so, where did you put the jack?
Old Jun 11, 2019 | 03:11 PM
xlt4wd90's Avatar
xlt4wd90
Whatever you do, do not put the jack under the rocker panel; it will collapse. There are these cross-structures inside the rocker panels that are meant for jacking. If you still have the original jack, there might be a picture of the areas where you're supposed to place the jack. However, that may not jack up the entire side of the van as you want for tire rotation. Maybe if you deployed two jacks, one in front and one in back.
Old Jun 11, 2019 | 04:39 PM
87&97Aerostrar
I only have one jack.
I'm thinking about trying the area where the transmission support cross member attaches to the unibody.
Old Jun 12, 2019 | 11:10 AM
DFord's Avatar
DFord
Old Jun 13, 2019 | 05:51 AM
Jose A.'s Avatar
Jose A.
there are front and rear jacking points on each side and I use two jacks to rotate tires.
the factory jack is used to raise the rear and a hydraulic jack to raise the front, but both under their jacking points.
the jacking points are located behind the rocker panel sheet metal. They are flat and reinforced to handle the weight.
Old Jun 13, 2019 | 03:26 PM
87&97Aerostrar
Well here's what I did. A friend loaned me some heavy duty jack stands and I jacked up the rear and put them under the rear axle. Then I used the jack in the front. I think it was safer that way. The van was very stable.
Old Jun 13, 2019 | 09:52 PM
99f350sd's Avatar
99f350sd
Ya get a couple jack stands at Harbor freight..sounds like you need them anyway.
mark996
Jun 2, 2011 07:07 AM
tombob
Escape & Escape Hybrid
Oct 3, 2010 09:59 PM
Big-Red-Lariat
2004 - 2008 F150
35
Oct 26, 2008 10:11 PM
cwgoff
1997 - 2003 F150
Jul 12, 2004 03:15 PM
Jupiter Coyote
1997 - 2003 F150
Apr 20, 2004 01:54 PM
