Sponsored by: Auxito
Tire Rotation Question
Old Jul 12, 2004 | 12:07 PM
cwgoff's Avatar
cwgoff
Question Tire Rotation Question
I am about to rotate my tires for the first time.
The owner's manual for my 97 F150 gives two options for tire rotation, a 4-tire cycle and a 5-tire cycle (working in the spare). The 4-tire cycle seems to jive with other advice I have received about rotating tires (i.e., just swap from front to back on the same side). The 5-tire cycle, though, takes the passenger front to the driver back. I have heard that switching sides with the tires can cause alignment probs. On the other hand, I can see where you would want to switch sides to even out the wear across the tire. I also like the idea of working my spare into the rotation.
Any thoughts?
Old Jul 12, 2004 | 12:12 PM
mizzleman's Avatar
mizzleman
Either one would work. I've used the the front to back and vice versa with no problems. I also use the modified X which is LF to RR, RF to LR, LR to LF, RR to RF. It helps to compensate for the RF wearing a little more from left hand turns.
Old Jul 12, 2004 | 12:35 PM
cwgoff's Avatar
cwgoff
Thanks, mizzleman.
Ever have any alignment or shudder probs after a modified-X rotation.
Also, relative to my other thread about placing of jack stands, would an after market bottle jack suffice instead of a floor jack, or would you still recommend the floor jack over the bottle jack? I do not expect to get the missus to support me ponying up for a floor jack when we can get the tires rotated for $5 at Firestone.
Thanks for the help so far.
EDIT: Two more questions - if I decide to buy a floor jack, do you think I can get away with a 2-ton unit? And if I do get a floor jack, do you center lift at the center of the front frame cross member? What about the back? Okay, that was three questions.
Old Jul 12, 2004 | 03:15 PM
mizzleman's Avatar
mizzleman
A bottle jack won't have the lift range. You would need a cinder block or something to put it on even to reach the chassis or lift point. Even then, you may not have enough to get a jackstand in.
For a truck, I would get a 3 ton jack minimum, with a large saddle (the actual lifting point on the jack). For pricing, as the saying goes, you get what you pay for.
From what I just read, the rest of your questions are answered in the other post you started.
RumpityRump
Apr 10, 2015 07:24 AM
dagren99
Feb 23, 2011 05:40 PM
Big-Red-Lariat
2004 - 2008 F150
35
Oct 26, 2008 10:11 PM
farwhitenorth
Apr 24, 2006 01:03 PM
Lane Dexter
Nov 8, 2004 04:15 PM
