Modular V10 (6.8l)
P0193
Old Jun 10, 2019 | 03:34 PM
6door74's Avatar
6door74
P0193
Good afternoon all,
I posted this question in the van section but was advised i might get more help here. I have a 2006 E350 van with the V10. As i was driving home the other day, I got a CEL but didn't notice any change in performance. After getting home, I used my OBD adapter and got the code P0193 (Fuel Rail Pressure Sensor Circuit High Input) Is anyone familiar with this code and have experience or suggestions for it's diagnosis/repair? This is my family travel van so I will most likely take it to the shop but I'd rather not go in completely blind and at their mercy. Thanks in advance for your help.
Old Jun 11, 2019 | 08:40 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like a wiring fault - corrosion in the connector, that sort of thing.
If you clear DTCs, does it come back right away? Reason I ask is, sometimes a bad alternator or low battery can cause weird symptoms.
Old Jun 11, 2019 | 09:28 AM
projectSHO89's Avatar
projectSHO89
P0193
Could be any of the following:
Faulty FRP.
Open or intermittent circuit in the FRP wiring back to the PCM.
Shorted FRP signal line to power
Start with inspecting the connector on the FRP.
Old Jun 11, 2019 | 02:49 PM
6door74's Avatar
6door74
I cleared the codes and ran it for a little while and it didn't come back. I'll drive it a bit on friday and see what happens. I did notice this reading on the torque app though. Is that number high for fuel rail pressure? Not sure how accurate it is or if it is in fact related to the code i had.
Thanks
Old Jun 11, 2019 | 03:20 PM
krewat's Avatar
krewat
From what I just read, the fuel pressure sensor increases resistance as pressure increases. So any resistance at the connector or wiring will cause the PCM to see a higher pressure. And yeah, 60+ psi seems a bit high. I've only worked on the older model Fords that didn't have that sensor, and they ran at 28-30 at idle, and 38-40 under load.
Check the connector at the sensor first.
Old Jun 11, 2019 | 04:53 PM
projectSHO89
65 psi is correct for the 6.8L 2V engine used in the E-series.
Old Jun 18, 2019 | 07:09 PM
6door74's Avatar
6door74
So i cleared the codes and drove it a good bit on friday to include towing my daughter's car. So far the light hasn't come back on
jmo1112
Apr 7, 2018 09:25 PM
Rambo024
23
Aug 28, 2016 07:59 AM
Jason Delamarter
May 30, 2016 12:36 PM
Rod Bender
Nov 15, 2009 09:58 AM
Smokey1961
Jan 17, 2009 04:05 PM
