Started the dream!
Old Feb 16, 2020 | 06:00 PM
  #76
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
I am afraid that would increase the likely hood of braking things faster than I could afford to fix them. Hence the idea of staying with 33” vs the 35” I really want. Add in that I am getting older now and the 33” sound good to me as far as crawling in and out of the truck. With the lift to compensate the 35” tires thats getting pretty tall. Always wanted the 35” when I was young and now that it I am able to do it I am thinking that part of life is past me. Plus it might not fit in the garage with a lift and 35” tires. As I blab on and on you can see I have not made up my mind, lol. The smart/cheaper choice is 33”.
Old Feb 16, 2020 | 07:18 PM
  #77
i-w's Avatar
i-w
I had 35 inch tires with a 3 inch body and a 4 inch lift. it was not easy to get in and out especially with the wife. ( old truck)
now I have stock height 78 short bed with 31x10.5. much better BUT I wish they were 12.5 wide it would look much better.
im thinking of going 33x12.5 for sure next.
Old Feb 16, 2020 | 07:40 PM
  #78
73 hi-boy 428 fe
Finally got the pictures uploaded.
Old Feb 17, 2020 | 08:42 AM
  #79
Meridian_Mike's Avatar
Meridian_Mike
Looking good! Looks like progress.
Thanks for showing the pics of your bed.
Old Apr 18, 2020 | 12:27 PM
  #80
73 hi-boy 428 fe
Anyone have a idea why I can’t down upload any more pictures to this thread?
Old Apr 18, 2020 | 02:19 PM
  #81
flowney's Avatar
flowney
Are you getting some sort of error message or is this what they call a "silent failure"?
Old Apr 18, 2020 | 02:49 PM
  #82
73 hi-boy 428 fe
It just reloads me at either the beginning or a page or two up. No pictures.
Old Apr 18, 2020 | 07:09 PM
  #83
72rtchallenger's Avatar
72rtchallenger
I upload pictures going to go advance and clicking on paper clip instead of the square picture landscape beside it , they both appear to do the same thing but the paper clip has never failed to load a picture for me , were the square landscape picture I have had issues , of course maybe its just me
Old Apr 19, 2020 | 12:54 AM
  #84
Mitch Huested's Avatar
Mitch Huested
I'd blast the rust and put on a coat of a good quality undercoating, if it was me. Protect this awesome build, so it will last! Also, noticed the wheelwell rust of the upper end. There are cutouts you can buy that will give you a nice finish when you're done installing them. The shape of the cutouts are exact, at least when I did mine. Alos, when you do put these in, Drill a couple of drain holes in them on the wheelwell side. This will keep it from happening again. Really NICE build!
Old Apr 19, 2020 | 07:44 AM
  #85
73 hi-boy 428 fe
I am using the green bed. It off of a 1974 2wd truck. It is rust free! Have had this bed for about 16-17 years in storage. The yellow one is the original that has seen better days. I am in the middle of moving three cross members and the rear mounting pieces to the green bed from the yellow. About 300 spot welds drilled out between the two beds. Have 2 of the 8 bed bolt holes relocated. The rear has them marked already after you remove the mounting brackets. All others will need to be re drilled. One of the cross members has to be moved back from where the 2wd cross member set to line up with the highboy bed mounting holes. I removed the front cross member then skipped one crossmember. Removed the next two then skipped one and removed the rear mounting brackets. Also had to remove the bracket on the cross member one back from the rear. The cross member it’s self is in the right location but the highboy bed has a longer drop down piece to hit the frame. All in all only one cross member is left untouched. It is the cross member that is second from the front. All this so when you look under the bed it looks original, no spacers or cut rear mount. There are many ways to skin a cat and this is just the way I choose to do it.
Old Apr 9, 2021 | 12:53 PM
  #86
4drocket's Avatar
4drocket
been almost a year, loved reading ur build thread. wondering how she came together? great job and thanks for including us here
Old Apr 9, 2021 | 01:33 PM
  #87
73 hi-boy 428 fe
Yep, still same old problem with the pictures on this thread. 15 minutes of typing to just be gone. Lol. Still working on it.
Navy_Chief
229
Jan 18, 2020 01:40 PM
Aaron-71
237
Jan 24, 2018 08:32 AM
Dano78
183
Sep 11, 2015 09:25 AM
Aaron-71
123
Jul 7, 2015 05:37 PM
jtindale
188
May 26, 2015 11:04 AM
