No electrical power
Old Jun 12, 2019 | 08:19 AM
TA455HO's Avatar
TA455HO
Lead Gopher
If you guys want to run the 70 AMP Circuit Breaker that's fine - realize it is not original and has nothing to do with a restoration.
The wiring diagrams some point to are covering more than just F100/250/350. They also include the BIG TRUCKS.
As Bill stated the 70 AMP Circuit Breaker was only installed on BIG TRUCKS.
C3TZ-14526-A - BREAKER ASSY. FUSE - ELECTRICAL CIRCUIT - 70 amp. - Reset type
C-CT500/1100
N-NT850/1100 "Before Ser. 872,001"
H-HT950/1000
F800/1100, T700/950 "Before Ser. 872,001
C6TZ-14526-B - BREAKER ASSY. FUSE - ELECTRICAL CIRCUIT - 70 amp. - Reset button
N-NT850/1100 "From Ser. 872,001"
No F100/250/350 that I've ever seen had a factory installed circuit breaker. And it makes sense since they didn't according to the MPC, either.
Old Jun 12, 2019 | 10:46 AM
daveengelson's Avatar
daveengelson
A couple of years ago purchased a 'circuit breaker' thru Green's, the box notes it is reportedly a Ford Service Part #: C5TZ14526J : made by Metal & Control Inc. in Mass. I am not knowledgeable when it comes to automotive electrical circuitry so for years I ran a 40-50 amp breaker purchased thru local parts store w/out any problem thinking if the ALT circuit was going to trip rather it be at a lower amp value, goes to show what I know. Had I come across Crop Duster's set-up I would have gone that route.
local parts store, f
Old Jun 12, 2019 | 12:25 PM
Crop Duster's Avatar
Crop Duster
Since my truck along with most others on here is a modified. I'll go with a little circuit protection instead of having my Alternator gauge be the only fuse in that circuit. The electrical system in these trucks is primitive at best. You might notice that a few years down the road around 69 I think Ford finally started putting Fuse Links in the system to protect some of the equipment. I'm not a big fan of Fuse Links but they work.
Old Jun 12, 2019 | 03:33 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yep, I don't disagree with you at all - I'm just keeping history straight. Or trying to.
Old Jun 12, 2019 | 03:52 PM
Crop Duster
I understand.
Have you ever ran across what Ford charged to add the oil and alt gauges on a new truck?
Old Jun 12, 2019 | 05:30 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Prices fluctuated some but October 29, 1965 price sheet I have shows $14.40. Free-running hubs for the 4x4 are nearly $100!
Old Jun 13, 2019 | 04:30 AM
Crop Duster
$14.40 sounds cheap now but I was working in a local factory at that time for a whopping 95 cents an hour.
gmcbride
May 8, 2015 07:41 PM
DieHardChief
Sep 4, 2013 01:53 PM
70mazie
May 20, 2008 06:30 PM
nhancock
Aug 23, 2004 09:02 PM
moonley
Electrical Systems/Wiring
Aug 14, 2003 04:03 PM
