1996 Reverse light add on
Old Jun 5, 2019 | 08:48 PM
torq'ta 5 8's Avatar
torq'ta 5 8
show where you put it, when you get there, I put LED reverse lights in mine, and when dark they will turn out the solar lights in driveway, I thought about adding a small LED, but for now I'm good with what I got
Old Jun 5, 2019 | 08:58 PM
torq'ta 5 8
lowes/home depot
Old Jun 6, 2019 | 12:04 AM
TooManyMIce's Avatar
TooManyMIce
I solder/shrink wrap electrical connections. You can get shrink wrap with glue inside (marine grade IIRC) and that stuff is great. Doesn't slide off and doesn't let water in.
Old Jun 7, 2019 | 03:13 PM
Morlock77's Avatar
Morlock77
Does the automatic transmission have a reverse switch like the standard trans or is it controlled by the range selector on the side of the transmission where the shift cable attaches? Looking for the closest wire to the front of the cab to tap into for the reverse light on signal.
Old Jun 7, 2019 | 06:05 PM
torq'ta 5 8
on your MLP connector
posted by rla2005 (thank him)
Purple/Orange is the Backup Lamp circuit supply feed that leads to one side of the backup up lamp switch. The Black/Pink wire then goes to the backup lamps. Which in turn have the other side of the filament tied to ground.
Old Jun 7, 2019 | 06:17 PM
Morlock77's Avatar
Morlock77
I have the 4R70W and the wire at my reverse lights is black with pink indicator. So it should be the black and pink wire at the range selector on my transmission? If I read that correctly.
Old Jun 8, 2019 | 05:28 PM
Morlock77's Avatar
Morlock77
Finally got it done today because work was so slow. Anyway I ran the wires down the passenger side and hooked into some power blocks I have that way it leaves my battery terminals clean. Have switch run through the harness grommet through the blower motor box at the firewall and then spliced a wire from my reverse wire about 10in back from my range selector and spliced that into the wiring for the switch. So now my back up lights or the switch turn on the stock lights and the led. Thanks for the help guys.
Old Mar 30, 2021 | 10:24 AM
ylekyote's Avatar
ylekyote
Reverse lamps
I have a 96 Bronco with manual transmission and my Reverse lights will not work and all feeds and grounds are good so I'm going to install LEDs for backup lamps. How are you liking your setup so far? Any problems? Suggestions? Thanks!
Old Mar 30, 2021 | 02:30 PM
Morlock77's Avatar
Morlock77
It works great and had no problems.
tjc transport
Nov 5, 2015 04:37 PM
fordtruck661
Electrical Systems/Wiring
Nov 12, 2012 06:41 AM
MGeary1089
1997 - 2003 F150
May 6, 2009 08:03 PM
waynaferd
Mar 3, 2009 11:31 PM
windyhill
Aug 15, 2005 04:19 PM
