For my 2019 6.2L, the manual has a list of maintenance things to be performed at certain mileages and/or after certain length of times. For example, the first scheduled maintenance is at 7,500 miles OR 6 months, whichever comes first. The second scheduled maintenance is at 15,000 miles OR 12 months, whichever comes first. Had my 250 since November 2019 (15 months) and have only about 5,000 miles on it. I changed the oil and oil filter myself 6 months after purchase. I have not done anything else on the 7,500 mile/6 month maintenance list or the 15,000 mile/12 month list. I see no need after the first 6 months of mainly sitting in my garage to rotate the tires and perform other minor miscellaneous tasks, and then at 12 months (still fewer than 5K on the odometer) to inspect brakes and related parts, inspect exhaust and other driveline parts, lube, etc. I plan on using my Ford points to have scheduled maintenance performed the first three times, then after that I'll perform most myself. Am wondering if I need to be taking the truck into the dealer to be in compliance (warranty) with their maintenance schedule even though it doesn't make a lot of sense to me to do some many of the things when the truck isn't being driven much.
Any way you slice it, eventually a vehicle is going to "go out of warranty".... The rubber components (hoses, weather sealing, tires, v belts, etc) all have a limited lifetime. I guess my question is, why do you own a truck that sits most of the time ?
The only maintenance I preform that is time over mileage is my oil. I change my oil every 5,000 miles or 200 hours. I find that I do a lot of idling, especially since covid.
I go by mileage. I bought a small car a couple months ago for DD use, and already have almost 2k miles on it that aren't on my truck. I will probably be able to do once-a-year maintenance on my truck now...
Hobo
Answer - Why my truck (or any other vehicle that I own) sits most of the time is irrelevant.
Got in the habit of changing on mileage/hours or calendar limits - whichever comes first. Before I downsized to one truck, the F350 sat for most of the winter but I still preheated and ran it to the next town at least once per month, and changed the oil twice a year because I never hit the mileage/hours before the calendar limit. Funny things happen to oil that has acquired any byproducts of combustion, build up of acids, etc., and then acquires moisture through freeze-thaw cycles. Moisture + acids = bad. That's why I would at least run it the 100 mile round trip. Shorter or just idling tends to add moisture rather than the other way around. Found that to be true when maintaining an aircraft engine. Pull the oil filler cap after a 20 minute in-place run and see the drops of condensation formed on the underside - at least with the Continental metal oil filler caps. Not as obvious on the plastic. Down to one oil burner truck now, first oil change coming up as I like to do the first way early to remove any excess products of initial break-in. YMMV, don't try this at home, yes i know i am retentive and often mis-informed!
