Window Crank Removal Help
Old Jun 1, 2019 | 11:12 PM
Otterby's Avatar
Otterby
Is there a trick to removing the window crank handles? I assume they’re held on with retaining clips but I can’t even get my clip removing tool between the handle and the door because the gap is too tight.
Old Jun 2, 2019 | 08:35 AM
robski_1970's Avatar
robski_1970
Old Jun 3, 2019 | 01:06 AM
JohnNewb's Avatar
JohnNewb
My 59 and donor cab had a mix of handles. Most had set screws. One had a clip. I made a removal tool by bending a piece of stiff bailing wire. After 60 years all could be after market parts.
Old Jun 3, 2019 | 08:13 AM
G-Force junky's Avatar
G-Force junky
This is the tool you need although it’s possible to use a couple of picks or small screwdrivers
Old Jun 3, 2019 | 04:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
371877-S8 .. Screw & Washer - fillister head / #8 -32 x 15/32" long / Retains inside door & window crank handles to shafts / Obsolete
1957/60 F100/1100.
Old Jun 3, 2019 | 10:33 PM
G-Force junky
Oops I’m sorry🤥 I haven’t taken my apart yet and just assumed they were a different style.
Old Jun 4, 2019 | 09:58 PM
Otterby's Avatar
Otterby
It turns out I had two different window crank handles. One must be original like NumberDummy shows and held on with a set screw. The other must be aftermarket and was held on with a clip, that was practically impossible to access. That’s the one I started with of course and had to rip the handle apart to get it off.
Old Jun 5, 2019 | 09:44 AM
NumberDummy
The other is 1953/55 F100/900 and was held on with a clip, that was practically impossible to access. That’s the one I started with of course and had to rip the handle apart to get it off.
^ B5C-8123342-A .. 1953/55 F100/900 window crank handle. The clip (357550-S) used to retain it to the shaft was the same as used on 1950's FoMoCo cars and myriad 1950's GM cars.
There was a special tool that looked sorta like pliers, but much thinner. You inserted the jaws between the handle and its escutcheon (22618 in pic), moved it around and evidently the clip came off. A royal PITA!
Old Jun 5, 2019 | 10:43 AM
G-Force junky
The pictures I posted are for that style. It’s actually not very difficult once you understand it.
All that you do is slide the tool in and it catches the open end of the clip and pushes it out.
The clip usually points one of two ways length ways with the arm and almost always fly’s out so be ready.
As I stated earlier, it is possible to use small picks or flat head screwdrivers which I have done many times when I didn’t have the correct tool.
Good luck!
HVFDFIREFIGHTER1618
17
Feb 24, 2019 05:41 PM
hharris8
Dec 9, 2016 03:30 PM
Arnie333
19
Feb 13, 2008 07:22 PM
aztsm
Apr 14, 2004 07:55 PM
tortoise
Jun 19, 2003 09:20 PM
