Window crank removal - Need Help!
Old Feb 11, 2008 | 07:31 PM
Arnie333's Avatar
Arnie333
I have the tool they sell from National Parts Depot, but how does it work? I can't fiqure out how to get the window crank off to replace the plastic trim panel. I did try to search this but couldn't find an article.
Thanks for any help.
Arnie
Old Feb 11, 2008 | 07:38 PM
matt2491's Avatar
matt2491
I'm pretty sure its just an allen wrench that fits right in there on the crank/handle...
Old Feb 11, 2008 | 07:44 PM
Arnie333's Avatar
Arnie333
I took the screw out of the crank/handle, but it wont budge. I have the tool from NPD that they said was required to remove the retaining clip, I just cant find the clip.
Old Feb 11, 2008 | 07:47 PM
matt2491's Avatar
matt2491
I'm not sure I know what they are talking about. My handle slips off and on no problem when you take out the little screw. It might just be a bit stuck on the shaft. Have you tried all sorts of ways like wiggling it back and forth, trying to loosen it up to pull off?
Old Feb 11, 2008 | 07:50 PM
Arnie333's Avatar
Arnie333
I tried all that, with wd-40. I even tried the other crank just to make sure I wasn't going crazy.
Old Feb 11, 2008 | 07:51 PM
BobbyFord's Avatar
BobbyFord
There is no retaining clip. Just an allen or phillips screw.
Old Feb 11, 2008 | 07:53 PM
Arnie333's Avatar
Arnie333
I will give it another shot of WD40 and a little more leverage.
Thanks for the advice!
Old Feb 11, 2008 | 07:58 PM
tbritt's Avatar
tbritt
Not sure what your working on but my 65 had a set screw and a "C"clip and you have to press both ends of the "C" clip up out of a grove in the handle.....ain't easy but can be done, hope that helps
Old Feb 11, 2008 | 08:01 PM
matt2491's Avatar
matt2491
Well that's a different story from our '61-64 trucks. There is no clip for these door and window handles on mine.
Arnie, what year is your truck?
Old Feb 11, 2008 | 08:04 PM
Arnie333's Avatar
Arnie333
Sorry, not the window crank, but the interior door opener/release.
Old Feb 11, 2008 | 08:06 PM
Arnie333's Avatar
Arnie333
Its a 66. Is the "c clip" on the inside of the door, or between the release handle and the face metal?
Old Feb 11, 2008 | 08:11 PM
tbritt's Avatar
tbritt
not one on my "DOOR HANDLE" but the window crank did have a clip, not sure why the change on the 65 and even more on a 66........hummmmm
Old Feb 11, 2008 | 08:36 PM
ol yeller's Avatar
ol yeller
if its a c clip first i heard of on a 66. try running a rag behind the handle and shoe shine like pull the rag. c clips usually will fly off. watch ur eyes.
Old Feb 11, 2008 | 09:05 PM
William's Avatar
William
I use the wooden wedges you get at Home Depot, Push one in at the top and one at the bottom so they overlap. Carefully tap them togeater and the handle will come off. I suppose you could use four of these wedges but I have never had to do that. The rag trick is a new one for me but I bet it sure works for those C-clips. The window handles on our Slicks do not have clips.
Old Feb 12, 2008 | 07:35 PM
Arnie333's Avatar
Arnie333
LOCK TIGHT.... thats what was holding the door handle on. I had to carefully cut the old one off from the shaft with a hack saw.
I knew I wasn't going crazy.
Thanks for the help.
