Electrical problem?
Old May 30, 2019 | 07:29 PM
Chris1450's Avatar
Chris1450
Electrical problem?
So I went to do some shopping. I came out 10 minutes later, and my key fob would not unlock the door. Ok.. so I use the key pad on the door. It didn't work. So I unlocked the door with the key, and the lights didn't come on on the dash or anywhere. Also no fuel pump noise. I got in the truck and tried to start it with the key. It acted like there was no battery installed. For some reason I pressed the power button on the radio, and the power came back on, and the truck acted normal and started. Anyone else experience this? 2018 XLT sport, 4x4 super cab, 2.7 engine.
Old May 30, 2019 | 09:08 PM
KJ Smith's Avatar
KJ Smith
I have not had that happen.
FYI, under normal conditions, the radio will come on without the key being on.
My guess is a loose connection somewhere.
I think there have been some reports of bad batteries also.
Old May 31, 2019 | 09:58 AM
alloro's Avatar
alloro
Definitely as a first step check to make sure the battery connections are clean and tight. Second, if the battery is more than 4-years old you might want to consider replacing it.
Old May 31, 2019 | 05:18 PM
GABAR's Avatar
GABAR
It could have been just a system glitch.
I wouldn’t worry about it unless it’s does again and often.
Old Jun 5, 2019 | 03:26 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'd log every event. If you do need to claim warranty on it, you'll do a lot better with details than "this is the third time, it happened today and a couple of other times over the last few months".
Jamie Midgette
Jan 18, 2019 04:01 PM
2012 F250 6.2
May 6, 2018 01:07 PM
fastwheeler
Electrical Systems/Wiring
Nov 26, 2014 10:09 AM
pilot10
Escape & Escape Hybrid
Sep 1, 2006 04:45 PM
cbb
1997 - 2003 F150
19
Apr 5, 2005 05:51 AM
