Guess The OBD Code!!
Old May 30, 2019 | 09:20 AM
Shane McCormick's Avatar
Shane McCormick
I'm posting a video of my obd blink KOEO. I have been staring at this relentlessly trying to read the code and I cant figure it out!
Watch the video, Good Luck! Dont Blink! Let me know what you guys come up with!!
https://youtu.be/v897tgSuVQw
Old May 30, 2019 | 12:25 PM
sandymane's Avatar
sandymane
fixed this video for you. Appears to be Code 33 in Memory EGR not open intermittently
33
ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
https://www.youtube.com/watch?v=v897...ature=youtu.be
Old May 30, 2019 | 01:37 PM
Shane McCormick
Thanks for fixing the link! I got 33 as well but the blinks are so irregular I was unsure.
Maybe your tracking with the thread with da_lariot_chariot...could that egr be related to issues with the engine cutting out and stumbling while driving?
Old May 30, 2019 | 02:04 PM
sandymane's Avatar
sandymane
33
The O and M mean KOEO and Memory. The EVP EVR and PFE and maybe a short are possible causes as I understand it. Sandy
https://therangerstation.com/tech_li...gitcodes.shtml
Old May 30, 2019 | 08:35 PM
torq'ta 5 8's Avatar
torq'ta 5 8
my check engine came on half way to/from work, turn engine off and start right back, light out? until driven, finally found hairline crack(1" long) in green vacuum line to EGR, I had the miss at speed, but when I stopped miss gone? But EGR only works when at steady/cruise speed
Old May 30, 2019 | 08:49 PM
Shane McCormick
Thanks guys! I've found some info on troubleshooting the egr and components. I'll also be replacing the tps in the process. I'll get back on tomorrow afternoon and update my progress.
Old May 30, 2019 | 09:16 PM
torq'ta 5 8
here's a tps check, before you go buy, this place(fuel injection technican library) shows how to test check anything just about, I checked mine today, and the closed volts was too low mine read 0.65 dc volts, should be 0,95-0.999 dc volts, idle was Hi (875-950rpm)
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
read post #54 by broken wire - explains how to step by step if tps is off some
Beating The Idle Topic Like A Dead Horse! - Page 4 - Ford Truck Enthusiasts Forums
Old Jun 1, 2019 | 07:04 AM
EPNCSU2006's Avatar
EPNCSU2006
That's 111 all-clear. If it were 33, it would flash 33 twice before the separator, and 33 twice after.
Old Jun 1, 2019 | 07:48 AM
Eddiec1564's Avatar
Eddiec1564
Its a 89 truck, so only 2 digit codes:
Here is my post from few years back, photos are lost when FTE switched software over and I did not get a chance to save them in new album...
https://www.ford-trucks.com/forums/1...d-evr-fix.html
Old Jun 1, 2019 | 09:21 AM
subford's Avatar
subford
It reads all pass codes for KOEO and CM.
111 111 1 111 111
Old Jun 2, 2019 | 07:13 AM
EPNCSU2006's Avatar
EPNCSU2006
No, it's 111 not 33. Each hard fault code is flashed twice before and each memory code is flashed twice after the separator pulse. If it was 33, it would be 111,111, pause, 111, 111, pause, 1, pause, 111, 111, pause, 111, 111.
I would have thought it to be 2-digit codes also, but it's not.
another reference for the timing/sequencing of the flashes: http://www.thorssell.net/hbook/eectest.html
Old Jun 2, 2019 | 08:54 AM
vjsimone's Avatar
vjsimone
33 is only a KOEO/CM or KOER code, not a KOEO code.
Disconnect your EVP connector, start your engine twice and rev the engine a few times.
Then check your KOEO test and see if there is any change.
Have you checked KOER?
Old Jun 2, 2019 | 08:59 AM
subford's Avatar
subford
If Its a 89 truck with 3 digit codes that would mean he has a E4OD transmission.
I would say then he has all pass codes.
Old Jun 2, 2019 | 09:32 AM
vjsimone's Avatar
vjsimone
Yeah.
I've seen 3 digit stock computers back to 1990, but it would not surprise me if a late MY 89 had a 3 digit computer.
Could be a replacement computer.
He should induce a fault to verify.
Old Jun 2, 2019 | 10:09 AM
subford's Avatar
subford
Every F53 with the E4OD 460 that I have worked with had three digit codes.
There was also a 1989 F-series truck on this Forum not long ago that had three digit codes also.
Was there ever a F-series 460 truck with the E4OD that had two digit codes?
What engine and transmission does the OP have in the truck in question?
