Thanks for fixing the link! I got 33 as well but the blinks are so irregular I was unsure.
Maybe your tracking with the thread with da_lariot_chariot...could that egr be related to issues with the engine cutting out and stumbling while driving?
my check engine came on half way to/from work, turn engine off and start right back, light out? until driven, finally found hairline crack(1" long) in green vacuum line to EGR, I had the miss at speed, but when I stopped miss gone? But EGR only works when at steady/cruise speed
Thanks guys! I've found some info on troubleshooting the egr and components. I'll also be replacing the tps in the process. I'll get back on tomorrow afternoon and update my progress.
here's a tps check, before you go buy, this place(fuel injection technican library) shows how to test check anything just about, I checked mine today, and the closed volts was too low mine read 0.65 dc volts, should be 0,95-0.999 dc volts, idle was Hi (875-950rpm) Fuel Injection Technical Library » Throttle Position Sensor (TPS)
No, it's 111 not 33. Each hard fault code is flashed twice before and each memory code is flashed twice after the separator pulse. If it was 33, it would be 111,111, pause, 111, 111, pause, 1, pause, 111, 111, pause, 111, 111.
I would have thought it to be 2-digit codes also, but it's not.
Every F53 with the E4OD 460 that I have worked with had three digit codes.
There was also a 1989 F-series truck on this Forum not long ago that had three digit codes also.
Was there ever a F-series 460 truck with the E4OD that had two digit codes?
What engine and transmission does the OP have in the truck in question?
