1967 Brakes
Old May 29, 2019 | 10:28 PM
Wodog7's Avatar
Wodog7
1967 Brakes
I am in desperate need for brakes on my 67 f100 I am trying to decide if I should go Disk in the front or just put in some nice drums. Also what is a good brand and place to buy drums and accessories I can't seem to find a good website that can sort out all the parts I need. Any help would be appreciated.
Old May 29, 2019 | 11:21 PM
mrpotatohead's Avatar
mrpotatohead
I can tell you that I got all my parts from Rock Auto. They were all name brand parts. My 71 f-100 with power assisted drums will stop fantastically with no pull. I don't see the reason to convert to discs at all.
Old May 30, 2019 | 12:50 AM
GreyScar's Avatar
GreyScar
Couple $100's and you can Swap the Beams and be Done with it. 73-79. And Have Disc, Cheaper Maintenance................
Old May 30, 2019 | 01:35 AM
Kurttb1's Avatar
Kurttb1
I agree that an upgrade is probably the best unless you are looked to keep it stock, however, one issue with Ft Disc is fitting some aftermarket Mag wheels around them. however I have discs and just used an adapter to move my wheels out some.
Old May 30, 2019 | 03:36 AM
Djlink's Avatar
Djlink
Amazon
My parts guy spent the better part of an hour trying to find shoes and drums for what I imagine was a highway department 69. I say highway cause it was originally cal trans orange and it appears to have 3/4 ton brakes on a 1/2 ton truck. At the end of the search he told me to go to Amazon as they show specifications on what they are selling. I did and got the right parts at a good price, the next day.
Old May 30, 2019 | 05:49 AM
Tedster9's Avatar
Tedster9
Didn't '67 have the integral front hub & drum assembly like some of the earlier years?
The problem there, as an assembly these are basically unobtanium at this point. The brake drums are available all day long, however the hubs are not. Not new anyway. Not a show stopper, but it requires new wheel studs and using a press to un-install and re-install the hubs onto new drums.
Old May 30, 2019 | 06:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Wodog7
I am in desperate need for brakes on my 67 F100, I am trying to decide if I should go Disk in the front or just put in some nice drums.
1961/67 F100 2WD/4WD have 11" x 2" front drum brakes, 11 1 3/4" rear drum brakes // 1968/72 F100 2WD have 11" x 3" front drum brakes, 11 2 1/4" rear drum brakes.
1968/75 F100 4WD's have 11" x 2" front drum brakes, 11 2 1/4" rear drum brakes // 1973/79 F100 2WD & 1975/79 F150 2WD have front disc brakes, 11 2 1/4" rear drum brakes.
1976/79 F100/150 4WD have front disc brakes, 11 2 1/4" rear drum brakes.
Old May 30, 2019 | 08:48 PM
Wodog7's Avatar
Wodog7
Could I put bigger drum brakes on a 67 like maybe 3 inch in the front? Or would this require a new backing plate?
Old May 31, 2019 | 01:08 AM
Djlink's Avatar
Djlink
Wodog7, My 69 has 3” drums on it. I assume they were an option as 2” were also listed for that year.
Old May 31, 2019 | 01:51 AM
GreyScar's Avatar
GreyScar
Keep it Stock??????????????Do what?????????? Using all the parts from 73-79 is Stock, and 15" wheels were pretty Standard from these years, Ford probably made a Couple Billion Rims so wheels won't be a Problem.
Old May 31, 2019 | 02:25 AM
NumberDummy
Originally Posted by Djlink
Wodog7, My 69 has 3” drums (2WD only) on it. I assume they were an option as 2” (4WD only) were also listed for that year.
11" x 3" front drum brakes were standard equipment for 1968/72 F100 2WD
11" x 2" front drum brakes were standard equipment for 1948/52 F1; 1953/67 F100 2WD & 1959/75 F100 4WD
There were no optional drum brakes of any other size for these trucks.
Factory installed 4WD introduced in 1959 F100/250.
Old May 31, 2019 | 02:26 AM
Kurttb1's Avatar
Kurttb1
Keep it stock as in ((Keeping it original to the year of the truck.))
Old May 31, 2019 | 04:55 AM
Jim-Pro's Avatar
Jim-Pro
Here is what I did. Worked out great!
https://w.fordification.com/forum/viewtopic.php?t=86405
Old May 31, 2019 | 06:42 PM
Wodog7's Avatar
Wodog7
I think i will keep it original for now. 2 inch drums in front and 1 3/4 in back. What are some good brands for brake parts is Centric any good?
Old May 31, 2019 | 07:11 PM
mrpotatohead
Sure but Rock Auto has Wagner also.
