Sponsored by: Real Truck
oil drain plug leaking
Old May 29, 2019 | 06:21 PM
Bigdukesix's Avatar
Bigdukesix
Trailering
Hello out there!
Can you believe this...leaking from the oil drain bolt on my 08 F350 6.4 Powerstroke Diesel! Never had this problem before on any vehicle. Have tightened the snot out of it and still a couple of drops on my driveway. Any thoughts on fixing this besides the obvious?
Thanks in advance
Old May 29, 2019 | 08:51 PM
SnowPlowDriver's Avatar
SnowPlowDriver
I hope you didn't cause more damage by over tightening it. I've replaced my drain plug on a 6.2 recently. I like the drain plug Honda uses.an aluminum crush washer on the plug.
Old May 30, 2019 | 05:58 AM
don123's Avatar
don123
Take oil plug out and put a new plug washer on. If that doesn’t work maybe oil pan is shot. No need to tighten drain plug too much. 20 ft. Lbs Is good.
Old May 30, 2019 | 01:56 PM
Chuck's First Ford's Avatar
Chuck's First Ford
you are so lucky..... go get a lotto ticket.
I have replaced many because of damaged oil pans...
gasket or "O" ring.... since forever.. should be replaced every few years...
the oil drain pan.. holds back 5 pounds of fluid.... so WHY hammer it Tight..
its NOT holding up the engine.
Old May 30, 2019 | 02:40 PM
Diamnd1's Avatar
Diamnd1
I put an O ring on mine. No problem.
Old May 30, 2019 | 02:52 PM
Desert Don's Avatar
Desert Don
Originally Posted by Bigdukesix
Hello out there!
Thanks in advance
If that is the biggest problem you have with your 6.4, you are one lucky SOB!!!!!!!!!!!!!!!!!!
A/Ox4
6.7L Power Stroke Diesel
30
Jul 14, 2019 10:26 AM
littlegreenford
Modular V8 (4.6L, 5.4L)
Dec 14, 2008 11:29 AM
Robert6401
Oct 15, 2006 08:21 PM
Danny_Ocean
Mar 23, 2006 10:33 PM
OfficerDangle
30
Dec 31, 2005 08:29 AM
