Sponsored by: Innova
USB Charging ports
Old May 27, 2019 | 04:23 PM
beancntr76's Avatar
beancntr76
USB Charging ports
USB Charging ports - I am having no luck getting my 2016 F150 USB ports to charge a certain device...a Sony camera. I can charge my iphone and my wife's Android phone, but when I plug in the camera, I get a message that "this device is not supported". I don't want the truck to interface with the camera...just charge it up. In addition to the error message and no charging, having the device plugged in messed up my navigation until I restarted the truck. Has anyone else found this problem and is there a solution? I could not find any mention of this particular error message in the Owners manual either.
I also tried plugging it in using the regular 110 outlet and got the same message. I haven't tried the cigarette lighter port yet since I don't have a cable.
Old Jun 2, 2019 | 07:38 PM
GABAR's Avatar
GABAR
Are you using the OEM charging cable or an aftermarket one.
Old Jul 5, 2019 | 03:30 PM
Rick Cargo's Avatar
Rick Cargo
My question is, are these USB ports and "cigarette lighters" suppose to be constantly HOT? Mine will only stay hot for a few minutes after shutting down the truck.
Old Jul 7, 2019 | 01:04 AM
madsonp's Avatar
madsonp
Could be the USB cord you're using, cheap ones can cause issues, try getting a higher quality one.
Old Jul 7, 2019 | 07:24 AM
projectSHO89's Avatar
projectSHO89
Either use a "charge-only" USB cord to charge the camera or an appropriate USB charger that plugs into the power port.
Old Aug 9, 2019 | 08:20 AM
alltrucksexpert's Avatar
alltrucksexpert
There are different USB cables for different purposes. So, most likely your camera immediately tries to connect to the media system as a PC. Just take the USB cable for charging only. They are cheap
xmontex4
Jun 12, 2013 09:55 PM
GBuckert
May 12, 2011 09:50 AM
IXI MIKE R IXI
May 10, 2011 12:22 PM
orng1
21
Feb 7, 2011 03:47 PM
MAKO314
Aug 5, 2007 06:16 PM
