CPS sensor issues tests
Old Jun 28, 2019 | 05:55 PM
jessev1978's Avatar
jessev1978
Update!So the truck is running good! I have put close to 300 miles on it now. It's is EGR deleted and throwing a code for insufficient EGR flow. Will this cause any problems? I read were some are saying it will keep the urbobvanse open so you can't build boost and others say it's just a code and won't affect drivability. Which is true?
So to get it running good I removed the Camahaft sensor and low and behold found rust behind the sensor like another reported on another thread. I removed the large flaked reust and smoothed it out.
I also added extra ground straps and changed my ICP pigtail that I noticed one of the wires insulation had a cracked in it.
I also installed a 6.4 starter I got off if eBay for $65 shipped to my front door.it was a reman but maybe had not even a 100 miles on it...
Anyway the EGR issue is the only thing remaining at this point oh and tires. Truck had say for a little bit so tires are starting to dry rot...
This is after cleaning rust off very well.
You can see the layer of rust flake around screw hole.
dw200
2004 - 2008 F150
Mar 14, 2025 03:15 PM
tcfd1094
Jul 24, 2013 10:58 PM
ballbandit
Apr 12, 2007 07:41 PM
TommyH
Jul 31, 2004 09:58 AM
powerstroke 26
Feb 4, 2004 04:50 AM
