Sponsored by: Auxito
Shifter fork replacement 1997 4x4
Old May 24, 2019 | 03:36 PM
Peck_az's Avatar
Peck_az
I recently lost first and second gear. Troubleshooting indicates it's the shifter Fork. I can also feel wear in a third gear fork. My question is can I remove the top plate of the transmission in a 1997 without dropping the transmission.
Hopefully I can do it this way. Removing the transfer case and the transmission to do this would extend the job longer than I'm able to do right now
Old May 24, 2019 | 08:57 PM
Sam I Am's Avatar
Sam I Am
Yes, if it is a M5R2 in a 1997 F150 the top plate is removeable from inside the cab.
Old May 25, 2019 | 08:59 AM
Peck_az's Avatar
Peck_az
The access through the cab is much smaller than the top plate. Are you sure there is enough room to
Old Sep 22, 2024 | 07:04 PM
bluebellbus's Avatar
bluebellbus
5th Gear
Did you ever get an answer to this?
Old Sep 23, 2024 | 07:00 AM
manicmechanic007's Avatar
manicmechanic007
Not sure about the 1997s but all the previous trucks and Broncos had a removable tunnel cover under the carpet
The tunnel cover is pretty big, roughly 20 x 24 inches
We used to remove the seat first to make it easier
Just look up from underneath the vehicle and see if you see bolts that surround the tunnel cover or not
It should have a tunnel cover to enable you to do repairs like those shift forks
Old Sep 23, 2024 | 07:02 AM
manicmechanic007
The pins shear in those rails once in a while
Never replaced an actual shift fork on one, just the roll pins
Silicone those tower rail plugs back in there so they do not leak as quick
roadrash63
Sep 8, 2009 10:45 PM
Lefty980
Sep 26, 2006 10:45 AM
Wrecker
Jan 31, 2005 01:30 PM
bluestarva
Mar 10, 2004 12:01 PM
donkeychop0009
Offroad & 4x4
Jul 21, 2003 08:10 PM
