Brakes
Old May 19, 2019 | 07:08 PM
Bobchatelain's Avatar
Bobchatelain
Brakes
2018 f150. Hooked up my fifth wheel trailer today. The brakes work if I squeeze the brake control. They do not work when I step on the brake pedal. The truck has towing package from factory. Any ideas
Old May 19, 2019 | 07:42 PM
arl8733's Avatar
arl8733
4wd Low
Got the same problem. Did you ever find out the problem?
Old May 20, 2019 | 05:56 AM
senix's Avatar
senix
How do you know they are not working?
If you squeeze the controller, you hear a buzz at all wheels correct?
If you are stationary and look at the graph and place your foot on the brake does the graph change with the pressure you place on the brake?
Most of the controllers are pretty seamless now and will not react like older aftermarket controllers. You won't feel that jerk when going down the road and putting on the brakes.
Old May 20, 2019 | 06:18 AM
Bobchatelain
The graph does not show up when I press the brake pedal. Only when i squeeze the controller Also I have the trailer jacked up
Old May 20, 2019 | 06:22 AM
senix's Avatar
senix
No buzz at each wheel?
Pull the 7 pin connector apart and clean and confirm the connections
Old May 20, 2019 | 07:25 AM
FordTruckNoob's Avatar
FordTruckNoob
Did you remember to turn the gain up?
Old May 20, 2019 | 08:04 AM
wrvond's Avatar
wrvond
The fact that your brakes work when the brake controller is used demonstrates the brake system is working properly.
Note:
Your vehicle must recognize the trailer before the trailer can receive power.
Recognizing a Trailer:
1. Attach the trailer and wiring connector to your vehicle
2. Switch on your vehicle
3. Press the brake pedal for a few seconds
A confirmation message appears in the information display.
The trailer brake controller is equipped with a feature that reduces output at speeds below 11 mph (18 km/h) so trailer and vehicle braking is not jerky or harsh.
This feature is only available when applying the brakes using your vehicle's brake pedal, not the controller.
Old May 20, 2019 | 01:09 PM
Bobchatelain
Yes it is turned up
Old May 21, 2019 | 05:15 PM
Harley Beaver's Avatar
Harley Beaver
My 2008 f350 is doing the samething
Yes it is turned up
My 08 f350 is doing the same thing, works great on manual but not on the brake pedal, I’ve adjusted the trailer brakes, replaced the pressure transducer and brake controller, the green bars for gain show the pedal is working correctly.
I’ve discovered that if you make hard brake application with the brake pedal, the trailer brakes will work, which tells me that if I set my brakes to 3.5 on the controller, and only 1/2 the green bars show up, ( normal brake application) I should have brakes, unless I have a poor connection some where and it’s taking the voltage away from the trailer...so with that said anybody have a clear wiring schematic of the integrated trailer brake control system, the ones I’ve found on the internet are not clear enough.?
Old May 22, 2019 | 07:05 AM
WE3ZS's Avatar
WE3ZS
Since the trailer is jacked up its not going over 11 MPH, so "normal" brake controller performance will be reduced, maybe this is what you are seeing?
Old May 22, 2019 | 04:03 PM
senix's Avatar
senix
likely the 7 pin, truck side needs a look.
Old May 28, 2019 | 08:05 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The integrated controllers do not engage the trailer brakes with the pedal when you are not moving only the manual slide will. The only time I like this feature is when I'm sitting at a light with the brakes applied so in my case the hydraulic pump isn't running but with electric brakes your magnets won't be energized heating them up. I hate it in CG because if you don't get over the trigger mph you only have trailer brakes with the manual slide, the newer ones have a small voltage applied at low speeds but I dont think it's enough to stop the trailer just stop any jerking. It will keep the trailer brakes applied all the way to a stop but as soon as you let off the trailer brakes stop working. If you roll ahead at a light just remember your trucks doing all the stopping because of this stupid feature so be sure and keep you distance from the traffic in front of you. I feel you should have full braking power as soon as the truck moves but what do I know.
Denny
Wildcat313RE
6.7L Power Stroke Diesel
Apr 2, 2017 04:20 PM
Headviking
6.4L Power Stroke Diesel
Oct 17, 2014 10:35 AM
marspec
All Things Towing
Jun 30, 2010 09:35 PM
RussF350
Mar 27, 2010 10:29 PM
ws595
All Things Towing
Sep 10, 2005 11:11 PM
