Here we go again, Controller issue - Backwards readings for gain!!
Old May 29, 2019 | 09:34 AM
MBman's Avatar
MBman
integrated controller on my F350 , 2015 when I press on brake the gain goes from 6 down to 2 , instead of 0-6 like it always has. Brakes are not stuck and seem to be working , just backwards readout Im stumped ????Ideas ????/ Work with manual press but same deal
Old May 29, 2019 | 09:51 AM
senix's Avatar
senix
Strange, never heard of this issue. Any fault codes when you scan it?
Old May 29, 2019 | 10:09 AM
MBman's Avatar
MBman
Scan as in truck or controller? Should i just stop by dealer. Can they plug it in to check
Old May 29, 2019 | 10:12 AM
senix's Avatar
senix
Scan the truck, but the dealer will work and ultimately you will most likely need the dealers IDS to diagnose the issue. But being a 2015 I'd bet you are out of warranty for this type of repair.
Old May 29, 2019 | 12:29 PM
MBman's Avatar
MBman
of course I can replace the unit myself if its bad --- I think but probably has to be programmed to truck?
Old May 29, 2019 | 12:31 PM
senix's Avatar
senix
I think you would be ok since it is already enabled to operate in the PCM. I think your could just swap it out.
Old May 29, 2019 | 08:23 PM
MBman's Avatar
MBman
Thanks for your help. I unplugged, tightened the connections, shook out a tad of water , cleaned all connections , tested all lines , and when plugged back in all worked fine. We had a TON of rain here , perhaps just an anomaly . Ill keep an eye on it
Old May 30, 2019 | 05:25 AM
senix's Avatar
senix
Thanks for reporting back. I am unclear where the water was? Did you pull apart the 7 pin connector and that is where the water was?
Old May 30, 2019 | 09:32 AM
MBman's Avatar
MBman
yes the 7 pin plug ( from the trailer) I plug it on the side wall of the truck bed, it get a lot of weather there
BBD
2009 - 2014 F150
Jan 24, 2018 07:40 PM
Max100TN
Jun 4, 2015 04:12 AM
Mulcher88
Mar 21, 2012 10:09 PM
shelbyloree
Feb 24, 2009 01:15 PM
igotjam
All Things Towing
16
Nov 9, 2007 07:11 PM
