My C6 teardown rebuild
Hopefully i can keep this thread alive enough with pics and such to help another zero experience fella out down the road... Started tear-down last night, things were going very smooth until I got to the rear reverse hub section were I couldnt find the rear retaing ring that holds that whole section back into the tail shaft, cuz its missing ! no pieces, no nothing. Pulled out the reverse ring gear and found the #9 thrust washer looking like this, then found the reverse clutch jammed back over the inner race and stuck in place until I started pulling rollers and fighting with it for 20 minutes. Once that was out I could see springs laying around the rear piston... Thats where I called it a night, back at it today !
#9 Thrust
Rear piston springs
#9 Thrust
Rear piston springs
on
WOW I would take a guess and say " for sure something is amiss in that trans" NO laughing mater meant . I just redid mine I had help tho from Ken Collins C6 video. A great help but you still had to watch what you were doing. DON"T spill the valve body parts off the tray like I did. Had a hell of a time finding a pic of where everything went !!!! I just hope all is in the right place and it works . I used a B&M shift improver kit The street/strip version and a TCI 2400 high stall torque converter. Good luck with your adventure and hope all goes well for you.
on
on
Got your PM but no pics. which is alright. I know what a 4x4 pan looks like my friend lol . As I said I will check to see if he has one. Last time I was there he had a couple of them. Pans and used C6 ( big and small block bolt patterns) trannys are getting hard to come by up here as well. Used valve bodies are RARE IF you can find one for a decent price !!!! I am out and about tomorrow so I will drop in to see him. Get back to you later. .
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
kawasakiklx1
19
11-20-2017 08:17 AM
TheTinian
Offroad & 4x4
39
04-30-2009 09:31 AM
