5.8 start up idle problem
Old May 15, 2019 | 08:18 PM
Alex1056's Avatar
Alex1056
92 5.8efi. Had a low idle problem, 450 to 600rpms. Replaced Idle Air Control and the Throttle Position Sensor.
Now my start up idle is 1,000rpm. I manually quick rsv it and the idle is 850, which i believe should be 750rpms. Any thoughts? Im a newbie at efi sensored engines.
Old May 16, 2019 | 08:12 AM
jas88's Avatar
jas88
Did you set the TPS voltage?
Old May 16, 2019 | 08:48 AM
vjsimone's Avatar
vjsimone
Disconnect your battery for a few minutes for your Computer to forget the old TPS info.
Old May 21, 2019 | 12:36 AM
Alex1056's Avatar
Alex1056
I'll give it a try. Tnx.
stevefretz
Apr 18, 2018 08:53 AM
CHAD250CC4X4
Nov 15, 2005 01:15 PM
MSM0075
Nov 5, 2004 10:14 AM
superman0604
1978 - 1996 Big Bronco
Jun 1, 2004 06:43 AM
geoford
Sep 5, 2000 03:23 PM
